Question about LG LRFC25750 Refrigerator French Door
Fridge Condensation My refrigerator seems to have condensation around the water dispenser. The water also condenses on the inside of the door, next to the ice box. It drips down to the bottom freezer where it then freezes into icicles. My fridge is the LG Model LFX2597
  • 28 Answers
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
Posted on May 09, 2009
Why is condensate forming on the outside of the freezer door?
you may have a weak seal on the ice maker side of the door where the water dispenser is? letting moister condensate?
Mar 13, 2015 | Refrigerators
Why Samsung fridge has condensation around water/ice dispenser and drips every few hours?
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then
Jul 16, 2014 | Samsung 25 Cu Ft Capacity Stainless Steel...
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Inside sweating and turning to ice
sounds like condensation. place a film of vasoline on mating surface of gasket and make sure door is shutting good.
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
LG LRFC25750 Refrigerator French Door Logo
628 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
