Question about iSOUND 1690 TWIST WIRELESS SPEAKER & BLUETOOTH SPEAKERPHONE BLACK
It will not connect. Says it's discoverable but the red/blue light on the top just spins.
After it try's for a few minutes it turns off
How can I enable the Bluetooth in my handa forza 2007 motorcycle?
follow this instruction. God bless you
To turn on Bluetooth discoverability, first key on the motorcycle. Leave the kickstand down and the kill switch off to keep the motorcycle disarmed. Toggle the Mode switch back and forth between Eco and Sport modes at least 12 times. Once the motorcycle is discoverable, the green "Armed" light will flash for a few seconds (except on FX and XU models. With the FX and XU models, the red warning light will blink slightly faster). It may take up to 10 seconds for the motorcycle to become visible to your Bluetooth device.
Once discoverability is enabled, the motorcycle will remain discoverable until paired with a phone, or until the motorcycle is switched off. Once you have paired your phone with the motorcycle, you will not need to repeat the discoverability process to connect to it.
Jul 20, 2013 | Computers & Internet
I disconnected my blue tooth 232 and now it will not come back on, nor will my phone recognize it. What can I do? It will not charge either. When I plug it in it turns red and after about 2 minutes the red...
Try totally deleting the headset from the menu on your cell phone. Then once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. Here is a link for the pairing instructions:
Plantronics Explorer Pairing Instructions
Good luck from Headsets Direct!
Oct 17, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I can not pair my headset HS820 with my BB 8520. My BB does not recognize it...what can i do?
First Ensure that your Blackberry 8520 is in discoverable mode (Settings>Options>Bluetooth) once in Bluetooth hit Menu (the button to the left of trackpad, Select options to turn Discoverable on, once you have done that ensure your bluetooth is in Pairing mode (solid blue light, except Plantronics brand which will alternate Red and blue lights) then have the device search and it should find it, select connect, then enter the headset (typically 0000 unless Bluetooth owners manual says otherwise) and it should pair just fine from there
Hope This Helps!
William
Sep 20, 2010 | Cell Phones
Cannot figure out how to pair my jabra with my blackberry bold......both work....just wont connect
Go into your Blackberry's Bluetooth menu and after turning Bluetooth on, scroll down to Bluetooth Options and select the item. A new menu will appear, scroll to the item which allows you to set Bluetooth to be discoverable (by default, it's hidden). You may have to click on Options to find this menu. You can set it to be permanently discoverable (a security risk) or to be discoverable for just 2 minutes.
Turn on your Jabra headset by holding down the main button until the blue light stays on constantly.
Go back to your Blackberry Bluetooth menu and click "search devices". After your Jabra shows in the results list, select it to add it to your phone.
If prompted for a passcode enter either 0000 or 1111 (varies by Jabra model and by the country it's sold in).
Your Jabra should now be paired and the constant blue light will revert to an intemittently flashing blue.
If this has resolved your problem then please let me know by taking a moment to rate my answer. If not, then please add a comment and I shall attempt to assist you further when I'm next online.
Jul 22, 2010 | Jabra Bluetooth Headset with Adjustable...
How do I know if my bluetooth is in pairing mode
The Explorer 220 is not in discoverable mode until the light is flashing alternating between blue and red. This is done by holding the button as long as it takes.
So, the steps to pairing the phone should be as follows:
1 - Power on bluetooth on your phone. With most phones this is done by finding "Bluetooth" in the settings and tools menu and choosing the option for "on"
2 - Put the headseat in discoverable mode by holding the button for at least 30 seconds to a minute. The light should be flashing and alternately turning blue then red
3 - Then you may have to tell your phone to search for any discoverable bluetooth devices (warning if you have a computer or netbook with bluetooth capability your phone may find that too) be sure to wait until the phone shows "Plantronics" or "Headset" as an option
4 - Choose that option and click ok. Your phone will try to "auto pair". If that is unsuccessful it will ask for a code. That will typically be four zeroes (0000) for this particular headset.
The phone will tell you when pairing is successful.
Nov 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Dec 29, 2008 | Motorola Mobility RAZR V3
I have a wireless headphones the only number i can see is model f0461b on the trasmitter. The transmitter and headphone are not comunicating the lights are red not blue.How do i recalibrate them so they...
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Nov 19, 2008 | Audio Players & Recorders
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
  • Blinking Red
  • Blinking Red
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
iSOUND 1690 TWIST WIRELESS SPEAKER & BLUETOOTH SPEAKERPHONE BLACK Logo
61 people viewed this question
Top iSOUND Audio Players & Recorders Experts
richie46
Rob
Rob
wwlvictoria
wwlvictoria
Are you an iSOUND Audio Player and Recorder Expert? Answer questions, earn points and help others
