Question about iSOUND 1690 TWIST WIRELESS SPEAKER & BLUETOOTH SPEAKERPHONE BLACK
Isound will not connect
A red and blue light on top but comes on searching but doesn't connect. Says it is discovered on my iPad
Just hold the Bluetooth bottom while trying to connect to phone
Posted on Jan 04, 2014
So it was connected for a while. but now it's not. and it's a blue color. it won't turn off, it stays blue, and my phone cannot find it anymore in the bluetooth section. How can i fix this?
Do not know this is what I found on the internet have no experience with the hv-800
To pair the headset, please keep pressing the turn on off button until the red and blue light flashing. ( I think this translates to holding the power button in for a certain time period - think it got lost in translation from chinese to english - somewhere )
on the phone search for bluetooth devices while headset in pairing mode
if asked to enter the password, please enter 0000, confirm and then the Bluetooth enabled device successfully connecting with this product. The blue light will flash two times every 5 seconds after a connnection.
Sep 04, 2015 | Unknown HV-800 Wireless Bluetooth Music...
I have installed the adapter internally in the printer but my ipad doesn,t detect it what else do I need to do
Make sure the blue tooth adapter is set to "discoverable". Then open your blue tooth app and search for connections. You should be able to find it. After two minutes, if it does not find it, turn printer off, restart ipad. Try again. good luck
Mar 07, 2015 | Canon BU-30 Bluetooth Wireless Adapter for...
Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Feb 08, 2015 | Logitech Ultrathin Keyboard Cover
Why won't my isound Fire speaker charge? It only works if it is plugged in, and only has a red light.
when you ghave bought it.if it is old one chexk with batreey else check the connection
Jan 22, 2015 | Tablets & eReaders
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
How do I unlock a permanet password on my ipad
If its the login password a full restore is the only way ! You may have to go into DFU Recovery mode to do this.
Mar 02, 2014 | Apple Isound Isound-1599...
How do i connect my ipad to the hello kitty keyboard
After turning on your keyboard, the blue indicator light will come on for a couple of seconds, then go away. Next, press the button that says "connect" at the very top right corner of the keyboard. It looks like a wifi signal with a circle around it (I had trouble with this part, I didn't realize it was a button). Blue indicator light will start blinking, meaning that it's ready to connect. Go to Settings > Bluetooth (make sure it's on) > click on device. Voila!
Nov 29, 2012 | Hello Kitty Portfolio Case and Bluetooth...
Nokia bluetooth BH-105 not pair with samsung galaxy y duos GT-S6102
Press The power button for 10s or more of your headset. When both blue and yellow lights flashes then put on bluetooth of your phone and connect it.
It works. I know it cause i have tried in.
Mar 14, 2012 | Nokia Bluetooth Headset BH105
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
iSOUND 1690 TWIST WIRELESS SPEAKER & BLUETOOTH SPEAKERPHONE BLACK Logo
283 people viewed this question
Top iSOUND Audio Players & Recorders Experts
richie46
Rob
Rob
wwlvictoria
wwlvictoria
Are you an iSOUND Audio Player and Recorder Expert? Answer questions, earn points and help others
