Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Fridge keeps making "clicking" noise and will not get very cold
Keep hearing "clicking noise coming from fridge and it is not getting very cold
  • 532 Answers
The clicking noise is probably the unit trying to start but it cant because its too overheated,try turning it off for about 30 minutes to cool the compressor down,then put the thermostat at 3 for the fridge and not the coldest for the freezer and leave it there for a few hours to stabalize the temperature and see what happens.
Posted on May 09, 2009
Freezer is warming- up to 24 degrees now. something is running- should i unplug the freezer to keep the defrost fan from coming on until repairs can be made?
the fan is not a defrost fan? it helps to circulate the cold air into fridge and freezer. so when the fridge goes into defrost mode the fan and compressor stop running. if ur getting constant warm or heat? I suspect ur defrost timer is not coming out of defrost cycle? the heat is only suppose to last up to 20-30 minutes then back into cold mode? hers a trick u can use that may get u back into cold mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? if its stuck in defrost , it will now come out of defrost and u should hear the fan and the compressor come on, hope this helps let me knoiw if u have any more questions
Mar 16, 2015 | Refrigerators
Amana side by side stopped cooling and hearing clicking from compressor when I turn it back on
Compresser is low in coolent, Or a Problem with the (Compressor) From what i can make out from your info. How old is this (Fridge)?
Oct 08, 2012 | Amana 25.8 cu. ft. Side-by-Side...
Fridge seems to run too frequently
How old is the fridge? Newer units will run more frequently and make "running" noises.
Apr 30, 2012 | Kenmore Refrigerators
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Freezer temp and fridge temp not as they should be
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
Jul 19, 2009 | Hotpoint HSS25GFP Side by Side...
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
My fridge keeps making a ticking noise, sort of
The evaporator fan, inside the freezer will sometimes come in contact with ice and make this noise.
If the overload on the compressor is tripping it will make a clicking sound.
Mar 04, 2009 | Frigidaire Gallery Series® GLHT186H Top...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
499 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
