Question about HP DESIGNJET T770 Printer
Taking machine apart
I want to transfer my HP DESIGNJET T770 printer to another location.
I have 45.1:3 for t770
Posted on Dec 02, 2013
brett207
  • 231 Answers
SOURCE: does the HP DesignJet 1050c plotter have a counter?
This data is printed out on the Service Configuration Print
  1. Load the plotter with media.
  2. When the device is 'Ready' scroll the menu to the Printer setup options and press Enter.
  3. Once in the 'Printer Setup options' menu, use the arrow keys to scroll to 'Utilities', and press Enter.
  4. In the Utilities menu, use the Arrow key to scroll to 'Test Prints' and press Enter.
  5. Use the arrow key to scroll to 'Service Config' and press Enter to print the Service Configuration Print.
You should find the data you are after under the heading of Maintenance on the printout
Good Luck!
Posted on Dec 07, 2009
seeker5211
  • 1089 Answers
SOURCE: HP Designjet T770 HDD error
Did it ever work?
You are using the Post Script drivers, right?
Power down the printer from the back. Disconnect the power cord. Plug it back in and power it up.
Check the graphic language setting of the printer(look at the User Guide)
Resend the file.
Upgrade the firmware to the latest version (www.hp.com/#support)
Posted on Feb 10, 2011
Testimonial: "thanks, We actually had someone from another governmnet department that uses the exact same printer. and once we connected he gave the exact advice. "
  • 1116 Answers
SOURCE: Just got a new HP
Issue with the service station. Turn off and turn on your printer couple of times. Try moving the carriage assy., manually.
Still if it don't work then the service station would have gone bad. Needs to be replaced.
Posted on May 24, 2011
seeker5211
  • 1089 Answers
SOURCE: I'm getting 47:01 error on
It doesn't need cleaning, it needs to be replaced. It's located on the right side of the printer behind the ride side cover. If you haven't been trained you arn't going to replace the motor. After it gets replaced the printer has to be re-calibrated. If it is still under warranty, use it. Otherwise, get a designjet tech to work on it.
Posted on Aug 25, 2011
vinay229229
  • 1121 Answers
SOURCE: how to find star wheel
Are you tech guy?..If not don't try to open it..its is not so easy..Remove left coverRemove main PCARemove Spit onThere you can see the star wheel unit..
Posted on Feb 02, 2012
CODE ERROR 47/01 FOR HP T770
This is problem with the starwheel assembly, make sure that there is no paper stuck under it and restricting movement. The starwheel is the metal bar and little spiky metal wheels that guide the paper.
Dec 20, 2014 | HP DESIGNJET T770 Printer
How i can cancel the purge tube process in hp t770 plotter?
Here is a service manual that might help you.
http://www.partsnow.com/docs/service-manuals/hp-designjet-t770-t1200-service-manual.pdf
May 24, 2014 | HP DESIGNJET T770 Printer
I want to take my printer to another location
Take note of the various connections or get the installation manual ready. Unplug the machine, move it to the place you want and reconnect.
Nov 28, 2013 | HP DESIGNJET T770 Printer
Error 45.1.03 for t770
switch off the machine, remove paper and spindle of both roll & 2, close the roll covers, switch on the machine wait until ready mode appears, select load media, select roll 1. Load spindle in in the bank, verify properly seated or not, insert paper to load wait to printer perform load media..if successfully loaded issue closed..:Other services are not advisable to users only professionals can resolve the issue..
Feb 01, 2012 | HP DESIGNJET T770 Printer
Hp designjet 800 error 2:10
System Error: 02:10
Is a carriage failure.
Get someone to look at it, possible carriage assembly replacement
Oct 27, 2011 | HP DESIGNJET T770 Printer
21:13 error code in t770
There is a problem with the "service station".
You are going to need a tech to look at it.
Oct 01, 2011 | HP DESIGNJET T770 Printer
How to find star wheel motor in hp designjet T770 hdd printer
Sep 14, 2011 | HP DESIGNJET T770 Printer
I'm getting 47:01 error on a DesignJet T770, read something about cleaning a star wheel...What is it and where is it located?
Aug 24, 2011 | HP DESIGNJET T770 Printer
Service Manaul T770
error 59.2:00 for t770
Aug 16, 2010 | HP DESIGNJET T770 Printer
HP DESIGNJET T770 Printer Logo
Seeker5211
Seeker5211
