How do i fix my home stereo amp
Hi guys I have a marantz pm493 home stereo amp, I know it's old but is still an awesome amplifier. The problem I have is after a minute or two of Turing it on it shuts off, for about 15-20 seconds then turns on by itself, then off again 30 odd seconds later and so on and so on. Is this a simple cheap fix or should I just throw it away??
  • 528 Answers
There are a few things that could cause this to happen - but you'd need more electronics savvy and equipment to repair. Since things are made so poorly these days, you'd be better off taking it to a Stereo/ electronics Wizard for repair. Fixing it will bring you many more years of service, whereas throwing it away will doom you to usingthe modern poopie available. Have the Wizard do a tune up on it too - it could be just accumulated dust, an overloading capacitor, etc. I personally would first open it up and look it over closely with a magnifying glass, watching for burnt /blackened spots, heavy dust, smelling for burned electrical ( very unique smell). If you find heavy dust/dirt, you can use some electrical parts spray from your local auto parts store to clean ( use a solder flux brush to scrub stubborn or hard to reach parts). If that doesn't cure it, I'd take it to the Wiz and let him work his talents on it.
Hope this helps and thanks for using Fixya!!
Posted on Nov 28, 2013
  • 60 Answers
Sounds like an easy repair. My advice : bad capacitor
good luck!
4 Suggested Answers
SOURCE: Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Posted on Mar 10, 2008
  • 12 Answers
SOURCE: set keeps shutting down
It could be that the amp's overload protection circuit is being triggered by a feedback loop or other problem, such as a shorted or bad cable connection. Turn off the power and unplug the receiver. Look for problems, starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. Plug it back in and power up again. Immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine) before the delayed speaker amp output clicks on. Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component.
Make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!)
Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (For example, Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the Denon AVR-380X series.)
Posted on Jan 28, 2010
smarthome2
  • 1114 Answers
SOURCE: I have a Sony STR-DE597
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jan 14, 2011
Testimonial: "Unfortunately, it gave the answer that I feared. But at least now I know!"
Marantz pm493
Check the fuses if it has some. It could be a blown output transistor.
May 07, 2014 | Marantz Audio Players & Recorders
Marantz pm493 surround sound and tv
google search for the manual.
or
set the amp to all channel stereo or similar option so sound is set to come out of all speakers the same or in stereo as opposed to surround. See if it makes sound then if not check all connections etc, pull wires out and put then back in carefully
Feb 01, 2014 | Audio Players & Recorders
Hey Guys I have a Marantz PM493 amplifier and when trying 2 play the radio through the phono sockets all I get is a loud humming noise but if I turn the volume up very loud I can faintly hear the radio...
If they are marked "phono" then these are dedicated for the use of a turntable and one which will use a magnetic cartridge. You should use ones marked "tuner" or any marked "aux". Even a "tape in" would be better.
Aug 25, 2013 | Audio Players & Recorders
Hi we have a marantz amplifer and the headphone socket has gone, could you tell me if it can be fix and how much please, thank you martin
If you do the work, it is just the cost of the stereo plug. They are repairable. The amps cost a great deal to ship both ways. It should take about an hour. So if you have a shop do it expect to pay about 100 Dollars or less.
Mar 25, 2012 | Marantz Audio Players & Recorders
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
Where i can get an marantz pm493 amp volume knob also on the amp bass trible is now working and only 1 side speaker power is working any idea what is wrong..
you can get the know right from the dealer at this link http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx as far as the one speaker working, switch the speakers to make sure its the unit and not the speaker box, if that doesn't help you probably have a blown output in the unit itself,, since its a Marantz Its worth the cost of having it repaired,, as with all High end receivers or amps, Be sure the unit is in the off position before you attach or disconnect any speakers ,, if they short out,, our gonna blow the output
May 21, 2011 | Audio Players & Recorders
I have a marantz sr 7001 amp and am running canton 4ohm speakers to front and centre should my amp get really hot and go into protect mode when I am giving it some serious volume
it is not made to drive 4 ohm loads.also if you measure the impedance on the speaker,at some frequencies,it is closer to 3 ohms.This will cause the amplifier to shut down.Today's amplifiers are embellished specs.the old marantz 2325 was 125 watts a channel and weighed 80 pounds.It would eat alive some of the 1000 watt home theater amps of today.Marantz is very nice stuff.
Jan 03, 2011 | Marantz SR-6300 Receiver
We have a Marantz PM493 amplifier with turntable, Tape, CD and radio decks connected. Dropped something on the ribbon cables, now all we get is feedback sound from stack system.Could it be that the ribbon...
Hiya Sally_fisher,
Is the feedback sound a low hum and also does this 'feedback sound" occur whether it is selected to CD, turntable, or on all of them regardless of select?
Jul 06, 2009 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
How do I hook up a Kenwood KR11000G Stereo Receiver with a Kenwood C2 Stereo Control Amplifier and a Marantz 1152DC Integrated Amplifier ?
hey spanky, no worries, just about to go to bed...11.40pm here. Will follow up tomorrow:) Cheers mate
robotek
Jul 21, 2008 | Audio Players & Recorders
54 people viewed this question
 Grubhead
Grubhead
