Question about HP Pavilion Computers & Internet
The laptop charger just stopped working is a solution to repair it
When pluged in to the laptop it does not work it was working until last week and now doesn't seem to work at all do I need to by a new one or can it be fixed
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Mr. Mabelann i suggest you a new charger to buy if your charger is burned due to electricity. Me and my friends have a experience to repair a charger of our laptops but after some time it create disturbance like touch pad does not work properly. Mouse cursor is not working properly and often a problem of up and down.
I also recommend you to see your charger carefully with other wire plugs.
Posted on Nov 28, 2013
farhangM
  • 64 Answers
SOURCE: Several letters on a keyboard have stopped working
Bring it back to the repair shop. They should replace the keyboard.
Posted on Dec 02, 2008
  • 3940 Answers
SOURCE: My hp 6715s laptop wrecks chargers, im on the 6th
2 possibilities
Either unstable AC current in the house (Generally, other items that have AC adapters would be failing too)
Motherboard charging Circuit issue (Motherboard replacement)
Posted on Sep 14, 2009
SOURCE: Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Posted on Oct 31, 2009
  • 32 Answers
SOURCE: laptop will only charge when switched off
get orignal charger for acer aspire 5735 pc and then try again
Posted on May 06, 2010
SOURCE: My FN=F5 fucntion to transfer my screen over stopped working...
I found some webpage describing this, but not test it personally, hope they helps:
1. For Windows XP: See http://allabouteeepc.com/howto-fix-fn-f5-toggle-on-eee-pc-running-windows-xp/
2. For Linux: See http://forum.eeeuser.com/viewtopic.php?id=13035
Posted on Jul 23, 2010
Charging problem
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
Nov 03, 2012 | Acer Travelmate Series 5330 5520 5535 5730...
My laptop acer 5101awlmi wont charge my battery i have bought a new battery and charger the new battery worked fine until the power ran out. i can only use it now when it is pluged into the mains charger...
take it to be fixed my laptop did the same thing but i had vista at time
it is something internaly so you will need to take it in to a repair shop
Feb 07, 2011 | Computers & Internet
I have an ASUS X83V. All of a sudden the charger that came with the computer stopped working and the computer went dead. I purchased a compatible charger for the computer and it worked for about a week...
From the information you gave, my guess is that there's a problem with the power supply section of your laptop, or the chargers that you're buying aren't actually compatible... but it's more likely that it's the first case. If the laptop is under warranty, you should contact ASUS and get them to repalce the motherboard. If not, you could spend a lot of money replacing power cords every week. Good luck!
Sep 03, 2010 | Computers & Internet
Earlier my laptop shut down with no warning even though the charger was all connected and plugged in. now even though the charger is plugged in everytime i try to turn it back on the needs to be charged...
This could be caused by several things, but try the obvious first. I just bought a brand new power supply, and in less than a week the customer called and said it stopped working. I suggested she take the cord from the old charger and try it - it worked - the brand new cord lasted less than a week. The other thing that could cause this is a bad connection on the end of the power supply, going into the computer. It could even be a bad power supply.The last thing I can think of is a bad battery that won't hold a charge.
Aug 12, 2010 | HP Pavilion dv4000 Notebook
Does leaving handset in charger shorten battery life
I used to repair pagers for Motorola and back then the biggest problem we had was from bad batteries. Firemen would go on vacation and leave there pagers in the chargers while gone. They would return in a week or two and find that there pagers would not work. The chargers heat the battery while charging and this continued heating after charging would ruin the batteries. New chargers aren't as bad but it is best to cycle your battery. Run it until it needs charging, charge until charged then use until it again needs to be charged. Refrain from unnecessary charging. If you properly cycle a battery it can last for 2 or 3 years before replacing
Oct 07, 2009 | Avanti Microwave Refrigerator
2 possibilities
Sep 14, 2009 | Computers & Internet
Well my acer laptop is already 1 1/2 yrs old and now it has a problem...sometimes it works sometimes it doesn't.sometimes is cannot be turned one for weeks and it also does charge. i tried to turn on the...
my opinion if it powers but not boot its a hardware problem ...mostly Ram memory ...but if sometimes do not even power up the led or doesn't make at least a click like it trying to **** again an again ..that means that is something with the power system ...and has positions when some contacts are ok and works ...or so ...I can not be sure from what you told here ...but in general there can not be other cause but either physical ( electric) on the power source ..or the boot system messed up ...
Aug 31, 2009 | Acer Aspire 4315 Notebook
Problem uploading pictures
Remove any Camera CD software and let Windows try for its self Come back with the result.
Sep 23, 2007 | Fuji FinePix A360 Digital Camera
My PC won't run with ac /dc power!
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check. The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked. For more aditional info please post back. PS. Sorry for my bad english, I am from Romania, it is pretty hard for me to explain tehnical stuff in english.
Feb 12, 2007 | Sony VAIO FRV28 Notebook
Computers & Internet Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
