Question about Pool & Spa
Jadan spa model SP 601
Why is my Japan spa so noisy when the pump turns on every hour
2 Suggested Answers
  • 127 Answers
SOURCE: spa works when turned on but if turned off will
They are supposed to do that....it is a built in feature to dry the lines after use so they do not develop mold. If it does it constantly then I would say there is maybe a problem but if only once after use then that is normal. If you do not push buttons that is.
Posted on Apr 12, 2010
Waterway Spa Pump SP-15-2N22CD 342062015 2-speed, 230V, 8.0 A 1.5hp
see if heat setting is on maintain if on then turn off
Apr 27, 2014 | Waterway Pool & Spa
How do you replace the seal on a Hayward pump model sp-1615-z1-mbk
if seal leaking probably ruining seals replace whole pump
Sep 20, 2012 | Hayward Pool & Spa
Pump won't start
bad start up capacitor or replace pump
May 22, 2012 | Waterway Pool & Spa
Water is leaking out of the back flush hose when the pump is turned on not when it is off what can that be the gasket?
First with pump off be sure multi-port valve is turned to filter. Then start pump. If you then have water coming out of the waste outlet, then you're "spider" gasket may be bad. You will need the model number of the valve (SP710 or Sp 715 as an example, there are many other models) With the pump off you can remove the top of the valve. Depress handle before removing screws. Be sure the valve top is in the correct position when re-assembling. Only switch vavle with pump off, and handle depressed.
Aug 27, 2010 | Hayward SAND FILTER, PRO SERIES
Pump starts but then trips breaker ?
the pump motor has a short in it its pulling far to many amps thats why the trip pops out
Jul 30, 2010 | Hayward GO-KIT #2 HAYWARD SUPER II PUMP...
Sp 704
Usually It makes no difference which way that handle goes. You didn't indicate what model valve you have. The handle turns 360 degrees. I usually lift the handle up so there is no spring tension on the valve plate, makes it much easier to get the srews in. Be sure your gasket is in proper position. Only turn valve with handle lifted, and with pump off.
Jul 12, 2010 | Hayward SAND FILTER, PRO SERIES
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Using a hayward vari-flo valve model SP 710x32
Do not drain a vinyl liner pool mor than half way....ever... If you have a fiberglass, or gunite pool it is important to pull the hydrostatic plug under the main drain cover. If you live down a hill, or where there is a high water table, the water pressure underground can lift the empty pool out of the ground (more common in fiberglass pools). If you have a sand or DE filter switch the valve to waste. make sure that you have the skimmer turned off, and the pump is only sucking from the pool main drain (spa drain closed also), and turn the pump on. Make sure the waste hose is far enough away so you dont add any hydrostatic pressure.
Mar 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
