Question about Refrigerators
Switch the door around on Lec TF5517W Fridge Freezer
Switch freezer door around
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
stradeteox
  • 88 Answers
SOURCE: freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Posted on Jan 08, 2009
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
SOURCE: Lec Elan Fridge Freezer: Freezer
Check freezer door seal
Regards, Barry
Posted on Feb 26, 2009
HOW DO I FIX
I see nothing about checking freon level .
Nov 24, 2015 | Refrigerators
LEC Tn216 Fridge Freezer is freezing my food
is that not what freezers do . read you manual and adjust the temp settings
Apr 27, 2015 | LEC Refrigerators
Lec fridge-freezer TF5089 faulty door light switch - how do I remove the switch from the fridge to check it?
Prying it out is the only way I know of. When you get it partially out you may be able to get hold of it with waterpump pliers or regular slip-joint pliers adjusted for a wide grip, and pull it the rest of the way out. They are made to be removed this way, so it shouldn't be damaged. If you push in the button and the light remains lit your refrigerator section may not be getting cold, because a bad door switch can send out a signal that the refrigerator door is open, in which case the freezer may not be blowing cold air into the refrigerator section. The door switches are fairly cheap online, especially compared to a service charge.
Mar 22, 2014 | LEC TF50152W White 172 l Fridge Freezer...
How to fix lec l5026w fridge on top of freezer?
There should be brackets that would attach to the back of both to hold them together and in place, similar to a stackable washer and dryer
Sep 07, 2012 | LEC Refrigerators
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
How do I fit a new freezer compartment door onto my lec R43G fridge
my freezer is not cooling like it such and ice is forming in the back of freezer
May 03, 2009 | Refrigerators
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
