How expensive are multitrack recorder tables?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 25 Answers
Some are less expensive than others, you can get one for under $100 or for a top of the line full table it can get up over $1000.
Posted on Nov 28, 2013
Are there android apps for editing music together?
There are a ton of apps for digital sound editing, most of them are really powerful. I personally really like J4T Multitrack recorder, its a very clean and easy to understand design making it really easy and intuative to use for the expereienced sound editor.
Nov 28, 2013 | Audio Players & Recorders
What kind of sound editing would I use a multitrack recorder for?
Any editing that you would do with sound, be it mixing music, or editing a video's audio track you would use a multitrack recorder. Most commonly you would see people useing multitrack recorders to edit instrument recordings together.
When did multitracking start? who invented it?
In 1955 Ross Snyder developed the first 8-track recording machine, which was the beginning of multitracking
Jan 29, 2013 | Audio Players & Recorders
In have an new HP and instulled Audio Audition 1.5 while in multitrack view and am trying to record, I get a "Device ID out of range message" I've tried mostly everything.
Wow, it sounds like you didn't set up a device in the mixer for stereo input, or Adobe deadpanned that you wanted to record mic in and didn't ask to fix that going into multitrack. I've seen that often enough teleconferencing from WinXP swapping audio devices in and out, but by Windows 7 and 2011...this is a surprise. Just activate the appropriate line in in the input mixer in Windows (or more likely, your multitrack input mixer's controls.)
Surely this isn't it, and Adobe wants you to walk through the input level test modules first?
Mar 13, 2011 | Adobe Audition 3 for PC (22011292)
Fostex MR-16 Multitrack Recorder The screen
Hi, try and reset it. it will come back to normal.
Take care.
May 18, 2010 | Fostex Mr16hd 16 Track Digital Recorder
Mic/line inputs Yamaha md8 Multitrack recorder not working
A little testing is required to nail this down.
1) Will a standard mic work in either channel?
2) Will a line level source work in either channel?
It is likely that either the power supply for the phantom power or the supply for the mic pre-amp IC has failed or the IC itself has failed. If a standard mic works, then it is the phantom power supply that is faulty.
I am not aware of any service manual available other than from Yamaha directly (for a price of course...)
If you can update this with the test results, perhaps we can walk through this repair.
Dan
May 12, 2010 | Tascam 2488 Portastudio Multitrack...
While recording through firewire solo cannot hear input but hear
  1. What version of Audition?
  2. What version of Windows - or other OS?
  3. Edit View and/or Multi-Track view issue?
  4. Are you recording in Multitrack view, then listening in Edit view?  Each has its own hardware setup..
My best guess is that one of these thigns are true:
  1. You have not enabled monitoring
  2. In multitrack view, I believe you have to send each signal to the master, and then enable monitoring for the Master... but I can't remember for sure.
Post back to let us know
Nov 24, 2008 | Adobe Audition 1.5
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Hooking up my mpc2000xl to dp01
The DP-01 does not have a MIDI-In function. Instead, it allows you to plug the MIDI device into the signal chain. Plug the MIDI device into the DP-01 by using the MPC2000xl analog 1/4" jacks on the back, marked "Stereo Right" and "Stereo Left" (right next to the headphone jack at the rear top left). Run those 1/4" cables to the front of your DP-01, into the 1/4" jacks provided.
Hold the Assign button on the DP-01 for the LEFT channel and touch the REC key for the channel you want to assign it to - the REC light will flash red to let you know the routing was successful. Do the same for the RIGHT channel.
You should also plug the MIDI-Out cable from the DP-01 into the mpc2000xl so that the clocks of the devices can be synchronized.
Nov 14, 2007 | Tascam DP01 All-In-One Recording Package...
378 people viewed this question
 Grubhead
Grubhead
