Question about Hitachi TRANSISTOR INVERTER VWS25LD3UH NEW SURPLUS
HFC-VWS model no vws33hf3eh - Hitachi TRANSISTOR INVERTER VWS25LD3UH NEW SURPLUS
How to find HFC MAC ID?
You MAY be able to pull it up by connecting your computer directly to the modem via ethernet cable, then typing the web address, below, which should bring up the modem's internal menu and interface:
http://192.168.100.1/RgSignal.asp
Jul 19, 2014 | Arris Cable Modem Sb6180 Surfboard Docsis...
My 2001 vw beetle spits and sputters and backfires when I give it gas will idle fine.
You need to have a diagnostic done on it - I would suspect the throttle position sensor ( TPS) but there are other sensors that could cause this too. getting a diagnostic done will save you a lot of money and time. Many auto parts stores and shops can do this for a nominal fee or even free, if you can get it there. if you cannot drive it there ( idling along is so slow) call around and find a shop that can diagnose and repair it. Most of the newer VWs require very vehicle specific equipment to diagnose, so make sure they are equipped for VWs.
Hope this helps and thanks for using Fixya!
Nov 02, 2013 | 2001 Volkswagen Beetle
I have a Mini Split Airconditioning Unit and I found a leak at the flaring where my Suction Line comes the Condenser. How can I fix the flare. Must I isolate freon first somewhere in the system so as to be...
There is seldom a means by which the refrigerant can be isolated in this type of system. Moveover, since the system has had a leak, the refrigerant in the system is no longer usable. It is made of HFC-125, HFC-32 and HFC-134a in specific proportions. When a leak occurs, these components will leak at separate rates and the remaining refrigerant (if any is left) is no longer capable of doing the work of a virgin refrigerant.
Refrigeration flare fittings are 45° and are made with special tools. While there are 'washers' that can be inserted into the fitting when it's exposed, they are not that effective all the time. Remember that the pressure at the condenser part of the system can well exceed 300 psig.
The refrigerant, Genetron 407C, is the replacement for HFC-22. It has no 'replacement' per se.
It's my opinion that this is an issue for a reputable HVAC technician, and not a homeowner. To do the job properly, you would need a new filter/drier, flaring tool and torch if the line is not long enough for it to be re-flared and reconnected, vacuum pump and virgin refrigerant. I would bet that the location of the leak is such that the system is all but flat at this time, and you need a precisely measured amount of refrigerant to re-charge the system.
If you've not yet done so, TURN THE SYSTEM OFF to protect the compressor from damage.
Jun 28, 2011 | Heating & Cooling
VW 2.3i 2001 model
No, your fuel pump has died, a very commom problem with VWs
Jun 14, 2010 | 2005 Volkswagen Microbus
Change the frequence
change the hfc mac address 192.168.100.1
May 27, 2009 | Arris SURFboard SB4200 Modem
What freon do I need.
r-12. yes you can buy it.
May 06, 2009 | 1999 Mazda Pickup
Oven won't light
Hey im sorry to hear that...
I fix many ovens., however not really familiar to yours...
However instead of searching for thermostat, try looking for either thermo-couple, falme flaiure device or falme safety device these are the three main termonologies used....
Hope this helps......
Im sorry cant provide you with a full on solution ... but my guess is that your is probably a thermocouple......
Jan 03, 2008 | Magic Chef CGS3760 Gas Kitchen Range
Hitachi TRANSISTOR INVERTER VWS25LD3UH NEW SURPLUS Logo
37 people viewed this question
Top Hitachi Electronics - Others Experts
Are you a Hitachi Electronics - Other Expert? Answer questions, earn points and help others
