Question about Mitac MSC-242 Motherboard
The cpu doesnot detect the HDD. there is a boot failure.
The pc doesnot bootup. Hard disk is not detected. Even with new HD. Fequent problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mitac Master
  • 2,226 Answers
Are the cables in right power cable and the ribbon or sata cable in right?
Posted on Nov 29, 2013
Samsung HD 503HI hard disk The following are
Run chkdsk/f after backing up your data! Then fit a new hdd if chkdsk can't fix the problem.
Oct 27, 2014 | Computers & Internet
Just bought a brand new Gigabyte M68M-S2P and im getting a Disk Boot Failure on my HDD which uses an IDE connector. Not sur whats going wrong, and going into the BIOS its not recognising the hard drive as...
Is this a new HDD? Disk Boot Failure means it cannot boot from the HDD. Plus you mentioned that it is not detected on the BIOS. You need to have this HDD replaced. Not even a reformat can help at all. It is a hardware problem you have there.
Aug 01, 2011 | Intel Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Hello Everyone, I have an old PC windows98 with maxtor 90840D5 hard drive. Sometime back I've removed the hard drive and attched it to the new PC, so as to access the old files.Today when I try reattach...
you need to detect your harddisk in bios setup.
For that when you power up the computer press "del" key to enter in bios.
Then check your harddisk is detected in bios.
If not cxheck power cable and ide or sata cable connected to harddisk.
Reconect both connection to harddisk then check.
Aug 01, 2009 | Maxtor DiamondMax 3400 (90840D5) 8.4 GB...
I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Jul 04, 2009 | Computers & Internet
PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE-M0F: exiting Broadcom PXE ROM. Operating system not found. how 2 solve or repair? help me...
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 14, 2009 | E-Machines eMachines Desktop PC
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
Evesham hard disk failure
is your bios still detecting the hdd and setting the right settings?
there may be a possibility that u will need to set this hdd as a slave and use another hdd to reinstall an os and therefore access all the infomation on the failing hdd before its too late.
hope this helps
Mar 31, 2008 | Computers & Internet
T4010 100Gb HD
try to fixed HDD inside the system some wiring maybe lessen.
If not solve, change the cable connecting the HDD.
if not solve; Try boot the system with windows installation disk.
if still see the problems.
HDD maybe damage
If the the disk is detected;
You should back up your files and install new windows if it is necessary.
Jan 02, 2008 | E-Machines eMachines Desktop PC
Hard disk is not detecting
hi, you should try downloading this http://www.seagate.com/www/en-us/support/downloads/seatools/
and booting off the floppy disk it creates will tell you if theres a problem with the drive and will probably fix it for you..
Happy New Year
John
Nov 18, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Computers & Internet Logo
Top Mitac Computers & Internet Experts
Alan Hohenbrink
Alan Hohenbrink
matt
matt
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
