Question about HP PSC 2355 All-In-One InkJet Printer
Will not print Photo paper - HP PSC 2355 All-In-One InkJet Printer
    Problem Solver:
  • 14 Answers
Photo paper may be too slick for the roller to pick up. Can you "force feed" the paper through? Maybe try cleaning the roller(s) with isopropyl alcohol to make it tacky again.
Posted on Dec 03, 2013
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
HP photosmart c8100 all in one printer 10x15 photo paper spits out when ever you try to print a photo from printer .new printer thanks Ray
do the normal copies of microsoft worf comes out properly without any spitting.then its the setting problem in your printer .you can change the settings through printer properties --just adjust the photo settings in your printer and it will print the photos.
but if the word document are also having the same problem its the printer problem get the replacement as the printer is new.
feel free for further queries.
thanks.
Sep 20, 2008 | HP Office Equipment & Supplies
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
I have Epson stylus TX121 printer but whenever i m using to print out photo, photo comes in orange and red color, pls help me ....
Hi
When switching from printing on standard paper to photo paper, you need the change the paper and picture quality settings in Printing Preferences.
Start > (Control Panel) Printer(s) > right click on the Epson TX121 printer icon > Printing Preferences > Main > tick Photo or Best Photo > under Paper Options/Type select the closest match to the type of Photo Paper you are using (see photo paper packet for guidance) > Apply > OK.
Use the same procedure to switch back to standard paper settings to print on normal paper again.
I hope this helps
Aug 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
HP Photosmart C5280 wont select printing paper when making a phot
Update drives from Hewlet Packard web site Run the installation C/D which will create a shortcut on your Desk Top antomatically for HP Solutions and one for Photo Essentials( N.B ensure you have the latest Photo Essentials 3.5 )
Then
Click on Start
Select Pictures from menue
Select the photo you want to print
Click on Print
This frame will allow you to select the type of paper and size of print etc.that you want When you have done this Exit out
From your shortcut
Select Photo Essentials (3.5)
Import that photo from your Computer to Photo Essentials by clicking on the appropriate symbol
Then select Print ( at bottom of that screen) Finally select Single Print
And Enjoy
Good Luck
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Sep 08, 2009 | HP Photosmart 8250 InkJet Printer
Black ink marks on prints from Epson R380!
Hello:
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
Susan
York, PA
smfree@comcast.net
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
PHOTO paper
The HP printer was prepared to use HP's photo paper to print borderless pictures among other things.
If you use a third party photo paper, try using A4 size, position the picture in the paper using MS Word or another WYSIWYG program and, after printing, cut the picture in the right size.
Dec 31, 2007 | HP PSC 950 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
