Not get any sound out of my hdm1 connector on my westinghouse 1080pure tv
  • 59 Answers
There are two possible problems.
1) the HDMI cable may have issues. Please try a known good one to eliminate this possibility.
2) the sound track from your movie my not be supported by the TV. As an example, the sound track could be DTS, you need to check if the TV also supports DTS.
Posted on Nov 28, 2013
3 Suggested Answers
roety
  • 585 Answers
SOURCE: Westinghouse HD Flat Screen 1080Pure TV - Shadows
Image burn can be permanent if the image was left on for a long period of time. You can try a pure white screen to balance the screen out. They sell DVDs online that have white screen and other screen correcting images to try an correct the damage done to your panel. here is one linked plasma or LCD both can burn.
best of luck
Thanks
Roety
Posted on Jul 14, 2010
Testimonial: "Thanks for your help Roety!"
SuperTech-11
  • 1591 Answers
SOURCE: my westinghouse 1080pure tv will
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
caps from www.digikey.com cost less than a buck a piece typically plus shipping, and usually arrive next business day.
Posted on Jul 11, 2011
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
I just bought an westinghouse 42'' led tv and im trying to hook my surround sound and my xbo 360 to it and i keep getting an no signal message everytime and it worked on my 42'' sanyo lcd...
Sounds to me like you are trying to use a composite hookup or a generic HDMI cable. If you get the official Microsoft HDMI connector it also includes phono audio outputs and an optical audio out for 5.1 surround,
Aug 27, 2011 | Westinghouse Televison & Video
best of luck
Thanks
Roety
Jul 14, 2010 | Televison & Video
Power but no picture on my tv
1.open back of tv and check the connector linked with lcd panel and pcb
2.check inverter board .check if any shortcirckut.
Nov 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse HDTV
I bought a 32 LCD Westinghouse TV 12 months ago. It stopped working so I brought it to a TV repair shop. They determined that the main board went out. The TV's power supply is working but there is no screen or sound, nothing. The TV repair shop had to call Westinghouse to inquire about a replacement part. Funny, Westinghouse doesn’t make replacement parts for this TV. Westinghouse said we need to ship it back to them and they will send us a new TV. Okay that sounds good but they wont pay the $100 plus shipping costs for us to ship the broken TV back to them. Also, they make you send them the TV before they send you the replacement TV. That can take days. If the customer's TV went out because of the company’s faulty product, the customer shouldn't have to dic around with this shipping issue – Waa, Waa! The TV was nice but for it to conk out in one-year shows what shi++y merchandise Westinghouse is selling their consumers. “Buyer Beware”
Feb 28, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
