Question about Kitchen Ranges
Fan in oven blows circuit breaker
Cb blows when fan turned on with Chef Stella fan forced oven (side by side)
    Scholar:
  • 43 Answers
The universal motor that runs your fan may be shot or there may be a short circuit to your fan.
Best thing to do if your not used to fault finding with an electrical tester is to ask your local appliance service person to make a house call. You can reduce the time he spends at your house by having access to the suspicious part of your oven ready for him when he arrives.
Hope this help. Let me know.
John
Posted on May 09, 2009
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
Where can I source a Chel Select Fan Forced Oven Manual from please?
You can try searching for Chef Select online but the age of your oven may make your search unsuccessful.
Jul 28, 2014 | Ovens
How to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
Jan 09, 2012 | Ovens
Converting fromTown Gas to LPG in gas cylinders
Hi
Thanks for using FixYa. If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Check to see if power is getting to the range/oven. If even a light won’t turn on then check for a blown fuse or tripped circuit breaker.
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Ovens
No power to Magic Chef Electric oven
I'm not familiar with this oven, but it ought to have protection against this kind of exciting burn-out.
This could be a fuse: find it and replace it, or it could be a circuit breaker: look for a reset button.
As I said, I don't know this oven; this attempt to help is based on the general idea that it ought to have some built in protection.
Dec 11, 2009 | Magic Chef 9815 Electric Single Oven
I am trying to replace the element in a chef upright electric fan forced oven. There are three wires white black and yellow and need to know which is live, return and earth? Is there an easy way to test...
Hi. Here is the information you seek. The black and the yellow are both hot wires since you are dealing with 220 volts. The White is the ground, or earth. IF you are not comfortable working with electricity you may want to seek out professional assistance. If not, at least turn off the power at the circuit breaker box or remove the fuses.
Jul 11, 2009 | Kitchen Ranges
Micro ios totally black . Had to reset the breaker ; is that a clue/
It has a fuse inside. Check the door switches while you're in there. The one in series with the fuse can weld in the "on" condition and blow the fuse and/or the circuit breaker.
Jul 23, 2008 | Magic Chef MCD990W Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Kitchen Ranges Logo
103 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
