Question about Dishwashers
Westinghouse dishwasher won't advance past prewash
3 Suggested Answers
SOURCE: dishwasher not emptying
No solution as yet, will most likely replace the dishwasher.
Posted on May 31, 2008
rylee_smith
  • 8619 Answers
SOURCE: My Dishwasher (Westinghouse907 series) will not
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 23, 2010
Westinghouse dishwasher error code i30
Not familiar with this particular model but the indication is for water in the very bottom of your unit. Either due to a leak or a faulty switch. A quick leak check is to tip your unit to the side and see if water dribbles out of the bottom. Side needs to come off and either find and fix the leak or replace the switch itself. If its just a leak and you tip the water out it will actually work till the leak fills up again.
Jul 08, 2013 | Westinghouse Dishwashers
Westinghouse SB905 flashing prewash light & stops
Possible that the water level senor is faulty . also check the functions of the program controller, remove and set the connections, check the drain valve/pump.
Jun 17, 2011 | Dishwashers
My Dishwasher (Westinghouse907 series) will not advance past the prewash/rinse cycle. I have cleaned out the filters. I also turned it off for a while and when I turned it back on it worked, but has now...
Hi
Thanks
Rylee
May 23, 2010 | Westinghouse 24 in. MDP531 RF...
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
May 31, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
Flashing lights
Not heating, check element and thermal fuse/thermostate. Regards Advisor
May 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
20 people viewed this question
Top Dishwashers Experts
