Question about NetGear WGR614 Wireless Router
Need to input 6 ports that was given to me
I was having trouble with my x box live. They gave me 6 port numbers that I needed to be open. I need to know how to install these 6 ports within the router interface
  • 1 more comment
  • jl_hamilton2 May 09, 2009
    all it says is WGR614
    sry it says V9 I just found it
  • jkpf May 11, 2010
    do you have the exact model number for your router? WGR614v##
    I will need that ##
    Sniper:
  • 125 Answers
First you will need to know your xbox's IP then if you log on to your router at http://192.168.1.1 or if you changed your router IP, please login to that. you will see port forwarding / port triggering. click on Add Service. for service name put something like xboxport1. Service User, click on single address and put the IP of your xbox there then the trigger port is one of the ports they gave you. connect type is tcp/udp and last is the start port and ending port. they are the same as the port number you put on trigger port.
add service for all 6 ports and that should do it.
Posted on May 09, 2009
    Problem Solver:
  • 15 Answers
RFTM, its in the manual. Open the router web interface in your web browser and log into and have a look around it should be in the firewall settings..
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
I can not connect to xbox live
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 23, 2011 | Video Game Consoles & Games
I have a belkin router and 2 xbox 360 connected to xbox live. whats the settings to have on the router which allows both of us to play multiplayer on games? at the moment one computer kicks us off live...
X-BOX
Jan 23, 2011 | Computers & Internet
I need to know how to open my nat type for xbox live
X-BOX
Jan 10, 2011 | ASUS (SL1000) Router
I neeed to open my 6 ports so i can play xbox live!
Here I have given a link so that you can open the ports for your xbox in your router .
http://portforward.com/english/routers/port_forwarding/Linksys/WRT55AG/ICUII.htm
If you do not have the port numbers, its here for Xbox
UDP ports 88 ,53 and 3074
TCP port 3074 and 53
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Dec 29, 2010 | Linksys WRT55AG Router
I have a Belkin wireless router with model number f5d7234-4v4 and want to change my NAT type to open so I can play on X Box live with my friends but it already says it is open and so does my friends'. So I...
Hi i got your issue
Try with the following steps ....
Step 1:Connect modem>>Router>>Computer
Step 2: Open the browser page and on the address bar type http://192.168.2.1
Step 3: Towards the left column below firewall click on virtual servers
Step 4: It will ask you for the password just leave it blank and hit submit
Step 5: Check whether any ports have been opened
Step 6: If not contact your x-box vendor and get the port numbers and the ip address of the x-box
Step 7: Come back to this page and enter all those numbers and click on apply changes
Step 8: I will give you an example how the numbers has to installed
Step 9: On description type -x-box ..
And on inbound port-enter the port number(as given by the x-box vendor)
And on thye it can be TCP OR UDP OR BOTH
Private is as same as that of the inbound port
Ip address is the ip address of the x-box
Step 10: Open all the port numbers and click on apply changes
Step 11: Towards the left column click on firewall and then disable it click on apply changes
Step 12: Hopefully this will work
If you any issues let me know or contact the 24/7 Belkin technical support 1800-2235546
Thanks .....
With regards....
Priya
Oct 20, 2010 | Belkin (F5D8231-4) Wireless Router...
It won't connect with xbox
Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
X-BOX
Click Here for more info
Dec 28, 2009 | NetGear Computers & Internet
My xbox360 scans and finds router but it will not connect. what is the problem?
X-BOX
Dec 26, 2009 | Linksys WRT120N Router
Xbox live conection
X-BOX
Dec 07, 2009 | Computers & Internet
I have a strict NAT on my xbox 360 and I can't connect to some xbox parties. How do I open my NAT?
X-BOX
Nov 20, 2009 | Zyxel P660HW-D1 Router
NetGear WGR614 Wireless Router Logo
71 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
