Question about Vacuums
Kirby Legend 2
I have inherited  a Kirby hoover however i havn't a manual with it and havn't a clue how to set it up to clean my carpet, i have bits everywhere, the hose is connected at the front, could you possible point me in the right direction as i am unable to find a web site to download a manual, any help will be greatly appreciated, many thanks
Chrissy
  • Amy J May 15, 2008
    I have also inherited a Kirby Legend 2, looks great but I haven't a clue how to work it - can't find an insturctions mannual anywhere on the web. Can anyone help... there are so many parts!
  • Anonymous Jun 05, 2008
    need a manual for kirby II legeng
  • 357 Answers
Here a guide that i have written for belt changing on the later model Kirbys. From there, you will see how to get a manual for your Legend.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Posted on Oct 16, 2007
Look mate if your packing legend 2 u'v already made the first an altimate step in carpet cleaning technoligy. i feel your question was slighty offencive as i have the privolege of owning the legend 2. u could right the manule onn the back of a rizla. just tune it t 24 ft of torque and then let the **** tear down the middle of ya pad sucking the finest dust into a vortex of love. to conclude i say "sort it out" x stanley ps it is addictive. own the dust, be the dust, ya get the point x x
Posted on Sep 07, 2008
Hoover platinum
Check the hose for carpet fiber, it may be starting to plug.
May 02, 2017 | Hoover Vacuums
Kirby legend 2 vacuum instruction manual
kirby.com or ebay for 1989 to 1992 manual
Apr 12, 2012 | Kirby Vacuums
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Legend II shampooer
make sure you have the exact soap added, tank filter cleaned after each tank fill up, turn tank knob all the way open, pull back slowly. try those...one or all has to fix it.
Jan 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
I don't know how to change the brush. HELP Kirby legend 2 vacumm
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=767761
Generic problem for all Vacuums
I don't know how to
Posted by mcwalworth on Jul 10, 2008
I don't know how to change the brush. HELP Kirby Legend II vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. To change the Kirby brushroll is to dial the belt off of the fan pulley and unlock the head to the bell housing, the head will come off. Then you turn the head over and remove the bottom plate by 2 levers the brushroll will be attached. Remove the brushroll and replace it with the new one with the screw head facing down to the carpet. Replace the bottom plate and install a new belt. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Kirby Legend 2 Vaccum cleaner
Did you ever find a use and care book for this vacuum.  I have one I could scan for you.
Jun 27, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
2,009 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
