Question about LaCie 4TB Biggest Quadra U SATA II Hard Drive
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Also single blue led light on the back of the drive is blinking, all the other drives have solid blue light
  • 75 Answers
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Posted on Dec 08, 2013
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: My LaCie 500GB Quadra spins and clicks. Have tried
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Posted on Sep 11, 2009
Testimonial: "Thanks for the quick reply. "
anaesarora
  • 180 Answers
SOURCE: what are the blinking light error codes for
the interphase between the raw drive and the usb cable is faulty or blown up.
use the raw drive from the casing to power it directly to pc it would start working
Posted on Sep 19, 2009
  • 162 Answers
SOURCE: LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
what os do you have
Posted on Mar 03, 2011
Lacie 2big 2tb drive LED flashing red what do I do?
You didn't provide details on what mode you were running or if this worked before and this is a sudden event. The manual doesn't appear to cover this situation of one blinking red light: https://www.lacie.com/download/manual/UM_2big_Quadra_EC_EN.pdf
but I found a YouTube video that may be helpful to you:
http://www.youtube.com/watch?v=V8KbtZYytC0
Sep 15, 2014 | LaCie "2BIG Quadra External Hard Drive - 2...
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
I am trying to format my lacie 4big quadra raid drive for FAT 32 so that I can use with Mac and Windows. My windows machine won't recognize it so I am not able to format and use with both Mac and Windows....
You cannot format a 4GB drive ALL under FAT32, it is NOT mathematically possible IT will be possible to Break Up the drive into Partitions, and then Format them FAT32. You need to keep each partition under 1GB.
Mar 13, 2010 | LaCie 4big Quadra 4000 GB
I have a 3TB big disk quadra and the blue light in front started blinking between red and blue. What does that mean? I still saw the drive on the desktop and access to the files, but I shut down the...
If the drive front LED alternates between Red and Blue, whilst the rear LEDs are normal, then it is a tempertaure warning. Ensure that there is plenty of space around the drive and at the rear.
Mar 06, 2010 | LaCie (301082U) 250 GB Hard Drive Array
My LaCie 500GB Quadra spins and clicks. Have tried (Mac) DiskWarrior and Disk Utility, but the drive ignores them and spins, clicks, and the blue light flashes
Sep 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Disk manager only sees 25% of it
your partition size is incorrect not disk manager
Apr 27, 2009 | Computers & Internet
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 4TB Biggest Quadra U SATA II Hard Drive Logo
289 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
