Question about Frigidaire FWS445RF
WASHER IS LEAKING AT BOTTOM ONTO FLOOR. I CAN'T SEE HOW TO TAKE BOTTOM PLATE OFF TO INSPECT WHERE LEAK IS COMING FROM.
    Sergeant:
  • 175 Answers
Hi..First remove the main bits,the Stator and hub.These
are the easy bits, just few screws and bolts.Grab the washing
machine and turn it upside down or on it's side so you can access
under the machine.It may have a bottom metal plate, held on by a
few plastic clasps.Just pop them open with you flat head screw driver
and you should be able to access the guts under the hood.
try this out..
thank u..
kindly rate my response..
Posted on May 09, 2009
Frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Apr 22, 2008 | Refrigerators
Leaks water out of bottom
hi friend,
Evidently you have reason to believe your washer is leaking. Probably there is water on the floor near the machine. Fine, then the first thing is some detective work. with an absorbent hand towel begin to inspect the areas where water enter or leave the washer. Those places are: 1. the hot and cold water inlet hoses located in the back and top of the machine and 2. the washer drain line, located in the back and bottom of the machine.
  • Step 2 One at a time, dry both ends of the hot and cold water hoses. watch for water to bead up. Water may be leaking from more than one place so don't stop with the first leak you find. Inspect all four possible connections and the hose itself. If there is a leak at a hose connection it's an easy fix. shut off the water supply of the leaking hose, unscrew the hose where it leaks and wrap Teflon tape clockwise around the threaded or male part of the connection. inspect the flat rubber washer in the female part of the connection. replace if it seems very worn. re-tighten the connection, dry and turn the water back on. check for the leak to return. If the leak in somewhere on the hose itself you will need to buy a new hose. Hot and cold water hoses are marked.
  • Step 3washingmachine3_thumb.jpg Next we need to check the hose where water drains from the washer. It comes from the washer near the floor level and usually inserts a male into the female of the washer hole. It then moves to the drain leaving the house. Again, dry the entire hose. Then you will have to run the washer. Use flashlight and inspection mirror to help you look for a leak during the draining process. If it leaks at the connection to the washer try reinserting and tightening the retaining screws. There usually are no threads to wrap. If that doesn't fix the leak or if you find a leak in the hose itself you will need to replace it.
  • Step 4 If you still have a leak under the washer it is probably in the drain hose between the drain pump and the outside hose or the short hose between the tub and the drain pump. This may be getting out of your level of competence. But if you want to be a Renaissance Man, give it a try.
    Unplug the machine. Now you need access to the bottom of the machine. depending on your brand you may be able to 1)remove the front by inserting a painters scraper and prying the spring snaps up, 2)remove the back by taking out screws and the rear plate or 3)you may have to go in through the bottom. With help tip it over on it's side. of course the machine will need to be empty of clothes and water as it's heavy enough already.
  • Step 5 However you access the inside bottom of the machine you will see a rubber hose coming down from the tub to a small electric drain pump then a plastic line will leave the pump and go to the back of the machine where it will meet up with the drain line you inspected in step 2. With your inspection mirror and flashlight look for water to indicate a leak. These lines are often held on by metal springs and can be moved or adjusted with open jaw pliers. If you find one of these hoses damaged take it off and bring it with you to your appliance store for a replacement.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • take digital photos before you remove any part. if you get confused you can use it as reference
    • don't work on the inside of the washer with it plugged in.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 24, 2009 | Maytag Washing Machines
    Water leaking from bottom of machine onto floor during fill and wash cycle
    there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
    Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
    Kenmore washing machine series 90 is leaking
    Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
    May 31, 2009 | Washing Machines
    Washing Machine Emptying
    Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
    May 27, 2009 | Washing Machines
    I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
    Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
    May 01, 2009 | Washing Machines
    Water on my floor
    Is it the bottom or coming out the door at the bottom? When your seal is bad it will leak, mine leaks only on handwashables and delicates. I have had to have my seal replaced twice in the three years i have had one, and the last seal was not put on right and leaks.
    Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    GE WBXR2060V1WW leak_transmission shaft and tub
    The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
    Nov 12, 2008 | GE WDSR2080D Top Load Washer
    Washing Machines Logo
    112 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
