Question about Sony VAIO VGN-NR220E/S Notebook PC
I'm using a vgn nr220e series laptop and i had problem with my scree. its turning on but the screen went just blank..i try rebooting it but still nothing hapens
  • petra_iz17 May 09, 2009
    hey geekman, i just bought this laptop few months ago and it couldnt be that bad as the end of the life of it. It work well the night before this happen then the next morning i switched on and screen just goes black, led lights are on except the cpu light
  • petra_iz17 May 10, 2009
    alright i'll try that. the hard disk LED didn't light up so i guess its the Hard disk faulty
  • Sony Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 09, 2009
  • Chris Hingee
    Chris Hingee May 10, 2009
    Did you connect an external monitor to the laptop, what was the results?
    Reseat the RAM module/s, it may need electrical contact to be re-established. If the doesn't work (the RAM might be faulty) test the RAM in another laptop or get your friendly computer shop to test them.
    Does the hard disk LED light up when you boot the laptop?
    Chech the BIOS to see if it detects the hard disk.
    Reseat the hard drive too.
    If the BIOS doesn't detect the hard drive it may be faulty, test it by connecting it to a USB hard drive adapter and insert it into a working laptop's USB port, if it detects the drive as an external hard drive and can open the folders and list the files then it's OK.
    If not the hard drive is faulty and needs to be replaced and Windows installed etc.
    Let me know the results.
Screen turns white?
Hi billy
Screen turns white is not much to go on.
The flat screen TV's CPU is faulty!
Nov 03, 2015 | Sony VAIO VGN-NR220E/S Notebook PC
I can not find wireless switch... wireless is turned off....... please help me to wireless turn on..... my modal no:- VGN-NR220E help me.......................................... my email id:- osho...
The Wireless LAN switch on your laptop is located to the right of the SD card slot and power indicator lights on the front of the laptop. If this does not work, the entire Users Manual can be accessed by going to:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGNNR220ES
Hope I helped!
Jan 17, 2011 | Sony VAIO VGN-NR220E/S Notebook PC
Windows wireless service is not running on my Sony VGN-NR220E laptop.
you have to right click on the small gray icon on the bottem right of your screen and a window will pop up with your wireless conections on it, select WLAN it will highlight in green when on, Hope this helps
Aug 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
How to setup projecter and sony laptop vgn-nr220e
Plug the vga cable from the projector into the laptop. Turn on the projector. Press the "Fn" and the key on your laptop to switch displays to change your display from the laptop screen to the projector.
Cheers
Sep 27, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
VGN-NR220E won't boot up
Bad memory can cause a system to hang as you describe.
If it is accessible, remove the memory cards, swab them with cotton swabs and alcohol and try it again.
Don't put the cards back in while still damp if you use rubbing alcohol.
Aug 19, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Sony VAIO VGN-NR220E/S Notebook PC Logo
159 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
