Question about Gestetner DSm675 Laser Printer
Functional problem within the copier - Gestetner DSm675 Laser Printer
2 Suggested Answers
  • 4 Answers
SOURCE: functional problem within the copier. sc1-195
chek the scaner lamp and all other tins that is copieing in the macine
Posted on Sep 15, 2014
Functional problem within the copier. sc1-195
Sep 15, 2014 | Gestetner DSc424 Color Copier
Functional problem
change the td sensor below the developer unit or if possibly change the complete developer unit
Jan 02, 2014 | Ricoh Aficio 1035 Copier
LD unit beam pitch adjustment incorrectly.
Jan 02, 2014 | Ricoh Aficio 450 Copier
How to Hard Reset Canon iR6000
press aditional function ,then 17+39 ( 1and 7 same time , 3 and 9 same time) again additional function .and select 95 th option in display (e355 and all ram clear ) press 2 and enter ..within few minitus mechine restart if restartting time just swich of mechine manually and on
Dec 14, 2013 | Canon imageRUNNER 6000 Copier
Error 000 switch power off and on again
This is error in the fixing assembly, the fixing assembly is not getting hot at all. First try resetting the copier error. You do this by pressing the additional function key, then press the 2 & 8 keys at the same time and then the additional function key again. Press copier, then function, then CLEAR, then ERR then OK. This will clear the error from the copier's memory. Be sure to do nothing else within the service mode, you could really mess up some settings and cause more problems than you have now. Power cycle the copier and if the error comes back up then further fixing assembly then further repairs of the fixing assembly will be needed.
Jun 23, 2011 | Canon CLC-700 Copier
Functional problem within the Copier. It sowing SC 101
look my friend 101 means that check that scanlamp light in main scan and check mirrors and lamp staplizer is worked
Mar 29, 2011 | Ricoh FT7950 Copier
Service Code - Fucntion Problem within the copier - Code SC541 Serial # of Mach J0122404128
this is a fuser code
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON.
if that fails, contact technical support. It will be necessary to replace the fuser roll and the thermistor
Jan 24, 2011 | Gestetner 2212 Digital Imaging System...
Describe your ricoh aficio 350 functional problens Problem sc 547-00
The applied power supply ac frequency
was detected at over 66Hz or below
45Hz, and the zero cross signals are
not detected within a certain period
within 500 ms after the main power
switch has been turned on. Pls check power supply board or try to use an AVR (autonatic voltage regulator)
Jan 22, 2010 | Ricoh Aficio 450 Copier
Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Dec 07, 2009 | Savin Office Equipment & Supplies
Gestetner DSm675 Laser Printer Logo
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
