9,583,507 to the nearest thousand - Office Equipment & Supplies
  • 2,113 Answers
9,584,000
Posted on Nov 28, 2013
I need help with rounding 1925 to the nearest 1000
1925 rounded to the nearest 1000 is 2000. Since you are rounding to the nearest thousand, you need to look at the digit after that. If the number is greater than or equal to 5, then you round up. Otherwise, you round down. Here, since the number after the 1000 position is 9, we round up.
Feb 01, 2017 | Cars & Trucks
Wat is the number 9385 rounded to the nearest emergency thousand?
I don't know how "emergency" adds to the question, but to round
9 385 to the nearest thousand, we look at the number to the right of the thousands column. If it is 5 or greater, we add one to the thousands column. If it is 4 or less, we don't add one to the thousands column. All numbers to the right are then set to 0.
In this case, the number is the thousands column is 9. The number immediately to the right of it is 3. Since 3 is 4 or less, we don't add 1 to the 9 and end up with 9 000.
Good luck.
Let me know if you have any questions.
Paul
Aug 27, 2015 | Office Equipment & Supplies
What would the answer be to the problem 39,000 rounded to the nearest thousand
To round a number, we first have to find the column in question. In this question, we need the thousands column, which has a 9 in it. Next, we go to the column immediately to the right. If the number is 4 or less, we don't add one to the thousands column and set all the numbers to the right to zero. If the number is 5 or more, we add one to the thousands column and set all the numbers to the right to zero.
In this case, the number in the column immediately to the right is a 0, so we don't have to add 1 to the thousands column, and rounded to the nearest thousand, we get 39,000.
Good luck,
Paul
Apr 18, 2015 | Office Equipment & Supplies
159.501 rounded to the nearest thousand?
Calculators usually have a position switch to do it for you.
Rounding Numbers to the Nearest Thousand - AAA Math
www.aaamath.com/g3_41cx1.htm To round numbers to the nearest thousand, make the numbers whose last three digits are 001 through 499 into the next lower number that ends in 000.
Feb 16, 2015 | Office Equipment & Supplies
What is 82,596 rounded to the hundreds, tens, thousands, and ten thousands.
Rounded to the nearest hundred: 82,600
nearest ten: 82,600
nearest thousand: 83,000
nearest ten thousand: 80,000
Sep 17, 2014 | Office Equipment & Supplies
How do i round numbers to the nearest thousand?
Identify the digit that sits at the THOUSAND position.
All the digits at the right of it will be replaced by zeros.
The THOUSAND digit itself may be left unchanged or increased by 1, depending on the digit that sat at the HUNDRED position.
If the digit at the HUNDRED position is 0, 1,2,3,4 the digit at the THOUSAND position is left unchanged.
However, if the digit at the HUNDRED position is 5,6,7,8, or 9, increase the old value of the digit at the THOUSAND position by 1.
Examples
5768 469 becomes 5768 000
5768 743 becomes 5769 000
5769 469 becomes 5769 000
5769 743 becomes 576 (9+1) 000 Patience
9+1=10, so you must increase the 10-THOUSAND digit by 1
Thus 5769 743 becomes 5770 000
If any other digit to the left of the THOUSAND digit reaches the value 10 (no digit), then increase by 1 the digit at the left of it.
Sep 09, 2014 | Computers & Internet
I neeed to round 740,692 to the place value
Round to which place value?
To the nearest million: 1,000,000
To the nearest hundred thousand: 700,000
To the nearest ten thousand: 740,000
To the nearest thousand: 741,000
To the nearest hundred: 740,700
To the nearest ten: 740,690
Sep 02, 2014 | Office Equipment & Supplies
How can i round to the hundreds or thousands?
Put the calculator in scientific display mode (SHIFT>MODE(Setup)>FIX. You will be asked to enter the number of fixed decimal digits. Enter 2 for hundredths, and 3 for thousandths. To round to the nearest hundreds or the nearest thousands, do it by hand as follows.
For hundreds
Locate the hundred digit. Let it be h.
If the next digit (the tens digits is less than 5 replace the 10 and unit digits each by 0. Your result will look like ...h00.
If the 10s digit is 5 or above (5, 6, 7, 8, 9) you must round up by increasing the hundreds digits by 1. Your result will look like ...(h+1)00
For thousands
Let the thousand digits be t
If the hundreds digits to its right is less than 5, replace it and the digits following it by 0. Your result will look like ...t000.
If the hundreds digit is 5 or higher, increase the thousands digits by 1 and replace the hundreds, tens, and units digits by 0. You result will end with (t+1) 000
Note if (h+1) or (t+1) give you 10, put a zero at their positions and increase the digit to the left by 1.
Example. 78997 to the nearest hundreds 78997 becomes 789(9+1)0 or 78(9+1)00 or 79000
May 22, 2014 | Casio FX-115ES Scientific Calculator
Round to the nearest ten thousand
What is 22.2036033112 rounded to the nearest thousand
Jan 04, 2014 | ixl.com Computers & Internet
jasbo
jasbo
