Question about Lands Phones
Audioline business class aub 1 - Lands Phones
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
We had a aube timer for years and we changed the outside poll light with a new top somehow when we screwed in the post lamp we hit one of the wires and when i went to turn it on the breaker flipped after...
Aube/Honeywell timers have internal rechargeable battery that powers the display.
Battery is not replaceable. Plus the electronics inside timers are susceptible to power surge.
Without the display, timer cannot be used.
These timers come with standard 1 year limited warranty.
http://waterheatertimer.org/Aube-timers.html
Jul 10, 2011 | Aube Technologies Aube 7-Day Programmable...
I have the lightswitch timer. i have it programmed but it doesnt' go on unless i touch the switch. it shows auto and on before the correct time of 7pm. if i shut off, then auto on and a flashing off...
Most in-wall timer manuals suggest re-setting timer to restore functionality.
If re-set does not restore timer, then timer is probably bad.
To download Aube manuals:
http:///waterheatertimer.org/Aube-timers.html
There are 3 things to remember about timers.
1) Line noise and bad wiring can affect electronics inside timer.
Buy cheap circuit analyzer at home center and test nearby outlet that is on same circuit breaker.
2) Aube timers have internal rechargeable battery and cannot be exposed to temperatures below freezing
3) Industry standard is 1 year limited warranty on timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 21, 2011 | Aube Technologies Aube 7-Day Programmable...
It just blinks on/off no matter how i program it and manual mode does not allow me to turn on. everything was fine until i switched to daylight savings time
You posted under Aube timers.
Resourceful do-it-yourselfer would include brand and model number for ease of identification and best possible free answer.
Open following link to identify timer and access on-line manual
Most digital programmable timers say 'reset' if timer stops functioning as expected.
Aube reset button can be pushed using paper clip. Usually hold-in button for 3-4 seconds.
Other timer brands and models use different method for reset, including holding down on-off button while reset is pushed.
If timer will not re-program or function correctly after reset, then timer is probably defective.
Aube timers have internal rechargeable battery that is not replaceable.
Most in-wall and plug-in timers have 1 year limited warranty. If Aube timer was exposed to cold temperatures, then warranty is probably voided since cold temperatures adversely affect battery life.
Mar 17, 2011 | Aube Technologies Aube 7-Day 40-500w Light...
How to change the day
You posted under Aube timer.
If you have different brand timer, add a comment with clear description of buttons so I can find the correct model number and post best answer.
Open following link to download manual for your Aube timer.
For example with Aube T1032: If you have different Aube timer, then open that manual for specific instructions.
Press PGM button to select Program1 ON.
So 1 and ON are displayed.
Press Day button to select choice of days for Program1 ON.
Press HOUR and MIN buttons to select ON time for Program1 ON
Next, press PGM button to select Program1 OFF.
Repeat steps for Day, Hour, MIN.
When program is finished, close and press the cover to return to normal operation.
Last, press and hold cover until AUTO is displayed, and now program will operate.
Feb 25, 2011 | Aube Technologies Aube 7-Day 40-500w Light...
Will your timer work inside a cold garage though the winter?
Fixya doesn't make timers.
Honeywell makes the Aube Timer
Aube timers are a new product with a rechargeable battery.
Batteries are susceptible to cold temperatures just as you suspect
http://www.aubetech.com/products/produitsDetails.php?noProduit=75&noLangue=2
Aube/Honeywell has a 'contact us' page
http://www.aubetech.com/contactUs/index.php
I sent an e-mail to Aube tech support about your question.
As soon as they answer, I will post their answer on this thread.
I also posted a page on Aube timers with links and manuals:
Nov 10, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
I do not understand the manual that came with my TH132 control unit. Can some one guide me so that I can set the heating for different times for Mon-Fri and different times for the weekend?
Aube technologies has a page with thermostat manuals
http://www.aubetech.com/products/list.php?noLangue=2&noFamille=1&app=1
Thermostat page shows 3 models for your TH132 (toward bottom of page)
Click the model number and it opens a second page
The manuals for each product are conveniently located on that second page, toward the bottom, along with a description of your product.
In my opinion, Aube (Honeywell I think) website is way ahead of the curve for customer convenience
Most other electric device websites have manuals located on a different page than the product
A lot of sites, like Leviton, have no manuals at all. Lose the manual, and you have to call their customer service like in the 1980's
Aube must want your repeat business.
Oct 17, 2010 | Aube Technologies Hardware & Accessories
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
Oct 11, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Audioline 20 Memory Speakerphone
1. Lift handset (releasing hook switch).or just press SPEAKER, ignore any noises or BT messages while you..
2. Press and release STORE key.
3. Press the keys for the telephone number
you wish to store.
4. Press and release the STORE key again.
5. Press the keypad number (0-9) you want
that telephone number stored in.
6. Your number is now stored.
Apr 01, 2008 | Audioline TEL 100 Plus Corded Phone
Lands Phones Logo
183 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
