Question about HP PSC 1350v All-In-One InkJet Printer
Problems with my printer
I cannot get the ink cartridges to adjust and stay adjusted. how do i reset my printer so i can see if that will help?
  • 527 Answers
If you provide brandname and model no. it can easy to suggest a better solution
Posted on May 09, 2009
My epson stylus tx121 cannot recognize my cyan ink cartridge. it cannot print any documents with blue colors. i tried to remove and replace the ink cartridge, turned the unit on and off but to no avail,...
All you need to do is to reset your device using the software resetter
this link :http://www.4shared.com/get/Tct88J0Z/ME320-TX121.html;jsessionid=915B4C7E4E51E44E0A13252FEA1C0E4F.dc516
Download the software run the program,accept the condition given and select the particular adjustment or do this steps;
1. Download the ME32 T121X RESETTER, extract it to your designated folder.
2. Run the Adjustment program and click ACCEPT to continue.
3. Click model name ..there are two options.ME 32 or T121X .
4. Click DESTINATION or location at present then click ok.
5. Click PARTICULAR ADJUSTMENT MODE then select WASTE INK PAD COUNTER.Then click OK.
6. Check two boxes the MAIN PAD COUNTER and FL BOX COUNTER then Click INITIALIZATION.
7. Icon box prompt and you to turn on and of the printer device>>then its all DONE>>>
Aug 03, 2011 | Epson Stylus C86 InkJet Printer
" Set Ink Cartridge "
Did you try disconnecting from the power for a few hours to reset the printer? Also, did you try a waste tank reset?
Mar 26, 2008 | Epson Stylus Pro 9600 InkJet Printer
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
The ink cartridge light is blinking. I have adjusted and cleaned the cartridges MANY, MANY times already but the light is still blinking. I urgently need to scan and email something and the scanner won't...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Oct 09, 2010 | HP DeskJet F380 All-In-One Printer
The print on b/w documents is too light. It is almost like it is printing a watermark. I have tried to adjust brightness setting and this does not correct the problem. I tried buying a new black cartridge...
You will need to go into the printer settings and adjust the amount of ink to use. It should be available when you goto printer settings. If it is not, then you will need to adjust it on the printer directly.
If there is a bar for adjusting the ink, it should be right in the middle. Likely it is set at the lightest settings. If it is set at the middle, then move it to the right to use more ink.
Jul 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson R285 need service utility
It sounds a lot like you have managed to reset the printer using the R290 adjustment utility and it now thinks that your printer is an R290 printer.
As a result it's rejecting the yellow cartridge (presumably the first to read empty since you reset the printer) and expects you to provide R290 consumables.
The only fix that I've heard suggested (and I'm still waiting to hear if it worked) if to get someone with a valid R285 to use the same adjustment utility to make a backup of the EEPROM data (nothing else), save this file, send it to you, and then for you to restore that same data to your own printer EEPROM.
As I said, I haven't heard if it works and I could be wrong about the cause but as I provide waste kits myself and have already had quite a few people report a similar issue I suspect I'm about right.
Hope that helps.
Martin
Jul 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How do you reset ink levels on canon pixma 310 after installing a refilled cartridge? Thanks theboss.
hi the boss.
i uninstalling and reinstalling the printer from the computer did not work, try to reset the whole system. the manual will explain how this can be done or you can leave the printer unplugged from the outlet for about an hour.
if those did not work, you may need to used a reset chip like the one below.
http://www.inkjetreset.com/
http://inkjetreset.ecrater.com/
http://www.absolutetoner.com/INKJET-CARTRIDGES/CANON-21677/4893704-Canon-Chip-Resetter-INK/ProductInfo.aspx
hope this helps.
regards,
voodoo
Jun 04, 2009 | Office Equipment & Supplies
Continuous Ink System Epson R1900 "Ink on" light illuminated
your R1900 chips has problem, you can try
www.inkrepublic.com
their chips works well
regards
Ruse
Oct 02, 2008 | Epson R1900 Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
HP PSC 1350v All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
