Question about Nissan Vehicle Parts & Accessories
Fuse location reverse lights
Where is the reverse switch llocated on 1999 nissian Altima
  • Nissan Master
  • 14,363 Answers
On your transmission.
Posted on Nov 29, 2013
How dangerous is it to drive a nissian altima with rusted subframe on left rear of ncar?
take it for a garage inspection or MOT. Could be very dangerous
if the corrosion has weakened the structure
Oct 27, 2014 | Cars & Trucks
I have a 2011 nissian altima and when i push on break the break light goes off but when i let off break light comes on what does it mean?
check your brake light switch on the brake pedal, more than likely thats where the problem is, when pedal is push down, the plunger on the switch is released to turn lights on, when you let up off the pedal the plunger gets push in by the pedal to wich its mounted, which inturn shuts the lights off. do you see how its suppost to work ? thats the only switch for your brakes , soooo yours is backwards correct ? must need re-mounted in its proper location........... OK
Mar 01, 2013 | 2011 Nissan Altima 2.5
Knocking sound from the front of my manual 1999 nissian altima
need to determine if its engine or drive train see if the noise stays when you coast or is it in the transmission could be anything from a gear issue to clutch issue may be a driveline issue noise coming from your wheels you need to find the general location of the noise then you can center the issue
Sep 18, 2012 | 1999 Nissan Altima
Llocation of map sensor 2003 nissan altima
Check here...
- 2.5L engine
- 3.5L engine
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 12, 2012 | Cars & Trucks
REVERSE LIGHT NOT WORKING. NO POWER TO BULBS. CHECKED FUSES DIDN'T FIND PROBLEM. MIGHT IT BE THE REVERSE LIGHT SWITCH? IF SO WHERE IS IT AND HOW TO REPLACE OR CHECK? ALTIMA HAS STANDARD 5SPD 2.5 LTR...
Below is the procedure on checking it as well as its location. If it tests out fine, feel free to email me at csautomotivecars@att.net and I will be happy email you a wiring diagram for that circuit as that will be your next step. I hope this helps and good luck.
Jul 19, 2011 | 2005 Nissan Altima
How do remove a vehicle speed sensor on a 1999 nissian altima
USUALLY THE VSS IS LOCATED ON THE TRANSMISSION HOUSING. RAISE THE VEHICLE ON THE JACK FOLLOWING SAFETY MEASURES( APPLYING HANDBRAKE AND WHEEL STOPPERS); LOCATE THE VSS, DISCONNECT THE ELECTRICAL CONNECTION AND REMOVE THE BOLTS ATTACHING THE VEHICLE SPEED SENSOR. REPLACING IS THE THE REVERSE.
Sep 05, 2010 | 2003 Nissan Altima
No reverse light changed bulb still same not sure which fuse it is 1999 nissan micra
This sounds like the reverse switch has gone bad. The switch is located on the side of your transmission and will have 3 wires sticking out of it
Sep 13, 2009 | 2000 Nissan Altima
1999 Ford Taurus SE no Reverse lights
the reverse lights are controlled by and part of the transmission range selector switch, this switch is the large electrical switch on the top of the trans where the shift cable connects.
May 20, 2009 | 1999 Ford Taurus
2004 nissian altima solenid problem
Your dad must have had his smarty pants on, the problem is likely the brake light switch, but I would get under there with a test light and a wiring diagram, make sure the switch has power before you replace it.
Mar 15, 2009 | 2004 Nissan Altima
Vehicle Parts & Accessories Logo
55 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
