Question about Welding Tools
I have a Miller Bluestar 2E. It welds fine with the high idle on. It won't pick up with the high idle off. What could be the problem?
I have a miler bluestar 2e Engine will not start it will barely turn over put in new battery still does the same. Help!
Posted on Dec 06, 2009
    Problem Solver:
  • 6 Answers
Sounds like u have a problem with switch need to reall ck the switch i believe there is a solined that energizes when it detects amps need to check that out first
Posted on Jul 12, 2009
    Sergeant:
  • 201 Answers
Sounds like govenor is not functioning properly.
amp draw should engage unit out of idle with engine at normal operation temp.
Posted on May 09, 2009
Miller bluestar 6000...generator works great...welding seems stuck on max amps...dial doesnt seem to change amp power...bogs engine..less than 150 hours...ideas???
could be a faulty power control swotch
I am inclined that the voltage regulator the controls the amp out put is faulty
Take it in for a specialist diagnosis to a welder repair shop
Nov 02, 2015 | Miller Welding Tools
My miller blue star 185 wont idle up when you start welding
Check your idle control module,
take the roof off of your welder, located at the top right of the inner control panel, it is the little red box with multiple white leads connected to it and labeled with alphabet letters.
pull the connectors, insure they are clean, reconnect them, start your welder and see if that corrects the problem, if not, you will need to purchase a new idle control module
Feb 25, 2015 | BlueStar Miller Bluestar 185 Dx Gas...
I have a miller bobcat 225 is lower power while welding, any idea?
First off, check all of your welding cables to make sure they're in good shape, then check for tight cable connections. Is your machine staying at low idle speed while trying to weld? If so, Switch the idle select into the 'weld' position and make sure the high RPM's initiate. Try welding again. Better? Could be a number of things, if not.
Dec 12, 2014 | Bobcat Miller 225 Welder Generator 907209...
I have a Miller Bluestar 185. Will not start with key. Put a new battery in it and it pull starts fine but won't with elec start?
check if 12v go on solenoid of starter when you turn key to start,mesure 12 v on starter when you turn key to start
if voltage drop to few volt,wire or connection are bad
Oct 31, 2012 | Miller Welding Tools
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
Need to remove a 9 hp engine from a miller bluestar 3500
Front panel and stator must be removed first,then separate rotor from engine.
Aug 27, 2009 | Miller Welding Tools
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Welding Tools Logo
1,529 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
