Question about AZOO Mignon Filter 60
My azoo mignon filter 60 is noisy.
Noisy impeller replacement motor replacement
Noisy hoover
1 Check the impeller to make sure it is not missing part of a blade or has something jammed in it that could throw it off balance.
2 Check the bearings on the rotating brush, especially at the belt end.
3 Remove belt and turn on. If noise still persists, it likely would be the motor is shot.
Jun 21, 2014 | Bissell Lift-Off Floors and More Pet...
WATERWAY NOISY impeller
loud motor check impeller for debris first then replace pump
Oct 13, 2013 | Waterway 1.5hp Hi Flo Above Ground Pool...
Pump is VERY noisy when running
Depends on the noise you are hearing. I would first check for debris caught in the impeller. If your pump is running but you don't have any flow you will get cavitation which sounds terrible, that would indicate a plugged line. Otherwise, many pumps are able to be disassembled. If you're really not sure, take it apart and run it with just the motor and see what happens.
Apr 12, 2013 | Pool & Spa
I have a kitchen aid dishwasher KuDR01TJBLO noisy when draining
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | KitchenAid Dishwashers
Blanco Dishwaser very noisy pump motor
the only thing you can do is take it to the place where they repair motors. like where they fix windings ect . im in ny so you have to check your area for one in your neighborhood. let me know if this washelpful to you
Feb 24, 2010 | Maytag MDBH965AWS Stainless Steel Built-in...
NOISY WHEN DRAINING ON OCCASION
This is a sign of a faulty drain pump impeller. the drive shaft that is connected to the impeller is stripping the impeller. you will eventually need to replace the entire pump soon.
Jun 06, 2009 | Fisher Paykel Eco IWL16
Noisy cycle and dirty dishes
Hi
If your dishwasher seems noisy, check these:
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 25, 2009 | Kenmore 24 in. 17362 / 17364 / 17369...
Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Mar 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Very noisy water pump
It is not uncommon for water pumps to become noisy , this will only be apparent when in use i.e. draining,replacing it is not generally a difficult or expensive D.I.Y repair , but avoid tipping the machine up. Ensure machine is unplugged / isolated from electric supply before comencing any repair.
Jan 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
AZOO Mignon Filter 60 Logo
62 people viewed this question
Top AZOO Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you an AZOO Fish Expert? Answer questions, earn points and help others
