Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Wont start,was runing two days ago,have fresh gas,checked plug
Plug isnot wet.
  • 1 more comment
  • north2star May 11, 2009
    carb was taken apart and cleaned,fuel line was checked for kinks and fresh fuel was added,there is a spark,still no start.
    it was sitin die wheni hitwhen i hitg for a yr. i then put fresh fuel in and ran it for ten min.i then put more fuel in and then it would start for a seconds andthen would die when i hit the gas.
    carb sreen is good,filter gdintake gasket gd,fuel pump not sure or to check,and what about the two screws on the carb.thank u
  • 11,896 Answers
Your carberator should be taken apart and cleaned with carb cleaner or solvent for at least an hour. Also check that your fuel hose isn't kinked. If your plug is not wet, then that means it isn't getting any gas to cylinder.
Posted on May 09, 2009
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield May 11, 2009
    did you check the carb screen and fuel filter for clogs?
    How good is the fuel pump? How is intake gasket?
  • Nate Stansfield
    Also check the fuel pressure. Make sure choke is clean and also try running half choke for a few minutes before going fully open.
  • Nate Stansfield
    Also check your air intake and filter for buildup and clog
Poulan p1500 16"/25cc trimmer wont start
If there is a good spark and good fuel getting to the plug, it may be the ignition timing is out, remove the flwheel and check the flywheel key has not sheared, if ok, pull the muffler off and take a look at the piston skirt through the open exhaust port, any signs off scuffing and it will need to come apart to assess the damage.
Oct 18, 2012 | Poulan Garden
Will not start with new parts?
is the spark plug wet when you pull it out ? Is your gas fresh? Did you check for spark? If all is good then I would check compression, then Carb
Oct 21, 2011 | Craftsman 25cc Gas Line Trimmer
Engine compartment partiallly submerged in water now wont start
1) you will need to drain the engine oil and refill it before you get it running again, the oil will be contaminated with water + change filter too.
2) you may also have water in the fuel, add a small bottle of methyl hydrate (gas line antifreeze) to your gas tank to neutralize the water.
3) remove your air filter and replace with a fresh dry one.
4) remove all the spark plugs and drape a clean white rag over the plug holes.
5) crank the engine over for about 30 seconds then have a look at the rag - if there are wet spots, there is water in the cylinders. repeat until you no longer get wet spots.
6) leave plugs out for a day for cylinders to dry out, then install fresh new plugs. as long as there is no internal damage, car should start now.
7) change engine oil and filter again to make sure all water is removed.
Mar 02, 2011 | 1996 Mercury Mystique
Ok so i have a 07 yz 250f it wont start i rode it a few months back no problem now it has set in storage and wont start it not the gas its all new could it be the plug or old gas in the carb
If you think it's the gas in the carb, use the carb drain screw at the bottom of the carb, and let it refill with fresh gas. You can also force a fresh fuel draw by covering 90% of the intake and turning over the bike. The suction created by the piston will force a fuel draw from the main jet. Verify that you are getting fuel to the plug by checking to see if it's wet with fuel after attempting to crank it over. IF that is true, then verify spark. Let me know the results and based on what you say, I can guide you on what to look at next.
Dec 08, 2010 | 2004 Yamaha YZ 250 F
02 jetta 1.8t Epc trouble shifting, wont start
Need the right software to diagnose the fault ,,,,sorry best advice here is dealer only
Sep 08, 2009 | Volkswagen Jetta Cars & Trucks
Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Jun 27, 2009 | Garden
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
225 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
