Question about Home Security
Factory code for sentry x075 - Home Security
3 Suggested Answers
SOURCE: sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Posted on May 27, 2010
SOURCE: wats the factory code for a sentry s3807...
First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. A good locksmith should be able to help you with It
Posted on Aug 09, 2010
What is the factory code for a Sentry SFW205GPC safe?
You must call (800) 828-1438 for combination retreivals.
If you need your combination, you must send a notarized letter stating you are the owner of the safe. (Note: the owner\'s last name must be different from that of the notary public). For locations that require a raised notary seal, use a pencil to shade the seal to insure that it is visible.
The notarized letter needs to include:
  1. Your name, address and phone number.
  2. The model number and serial number from your safe. The serial number is typically found on the front of the door, lower right corner on a small sticker; the right outside wall of your safe; or under the keypad/dial on the front of safe.
  3. Please indicate how you would like to receive your combination. Options include first class mail, e-mail or fax. Your letter must clearly indicate which method you are choosing to receive your combination, as well as the mailing address, e-mail address, or fax number to which it should be sent. Note that failure to indicate the method in which your combination should be returned to you will result in delays to the process.
  4. Special Circumstances
    • In the event you need to open the safe after the owner is deceased, your notarized letter will also need to include that you are now the owner or executor of the estate and need access to the safe. You must also include a copy of the ***** certificate.
    • If you hold Power of Attorney for the safe owner and need to access the safe, your notarized letter will also need to include that you are acting on behalf of the safe owner. You will need to include a complete copy of the Power of Attorney documentation to confirm that you have the authorization to act on their behalf in this type of circumstance.
    • If you also need a key for your safe, you can order them online:
      REFERENCE THE ACTUAL KEY LOCK (WHERE THE KEY IS INSERTED) FOR SMALL SAFES AND CHESTS
      For Personal, Home and Home/Office Safes: (Model numbers will begin with: S0 (S0310, S0400, S0407, S0408, S0409, S0410), S3 (S3300, S3310, S3401, S3410, S3417, S3421, S3460, S3467, S3470, S3710, S3807, S3870, S3877, S3910), S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, CS, CSW (CSW3460), DA (DA3831, DA3930), DS (DS3410, DS3431, DSW5781), KSW, MS, MSW, OA (OA3810, OA3821, OA5848), OS (OS0407, OS0410, OS0810, OS3407, OS3421, OS3470), SC, and X (X031, X075, X105, X125)): Indicate your model number and the safe serial number is found on the front right-hand side of the door, between the hinges.
Keys Sentry Safe Replacement KeysLost Combination My Sentry Safe Combination Sentry Safe Shop Keys Sentry Safe Replacement Keys Lost Combination My Sentry Safe Combination Sentry Safe Shop
Feb 10, 2015 | Sentry Fireproof Safe
Unlock password
A1-Locksmith Burlingame Ca 94010 provided this advice that sentry safe models x075 initially work with the default safe code 1, 7, 5, 0, 0. It is therefore important to re-program your safe with a new user code you have personally selected, to provide maximum security.
Aug 07, 2013 | Sentry Xo75 Security Safe Protect...
How to change combo on sentry safe X075
http://www.sentrysafe.com/pdfs/OwnersManuals/401149.pdf
Page 1.
This procedure will work with any subsequent pin change.
Oct 06, 2012 | Sentry Safe SentrySafe Model X075 Security...
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
Lost factory code for sentry safe model #d8W5840
did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
Dec 07, 2010 | Sentry Fireproof Safe
I had my safe for a year and i forgot the code i need the default code for my sentry safe x075 model
By Office1000 at 06/04/2006 20:46
"I bought a used Sentry Safe at a garage sale"
"I bought a business and it came with a Sentry Safe that is locked"
Help!
We get these requests everyday. Unfortunately, eventhough Office1000.com sells many Sentry Safe products, we don't have combinations for any of them. There is a quick and easy answer. It can be found on Sentry's webpage and we have reprinted here it for your convenience (though of course the details may be changed at anytime):
Lost combination:
First, find your safe’s Model and Serial Number.
The Serial Number is in this packet, and is also printedon the small label beside the door hinge (outside). Send a copyof this, a notarized letter (last name must be different than that of owner) stating you are the safe’s owner, and a check or money order for $12.00* (U.S. funds) to: Sentry Group, Dept. 200,
882 Linden Avenue,
Rochester, NY 14625-2784 USA.
If using a credit card (Visa/Mastercard only), call 1-800-828-1438
and fax your Model and Serial number with the notarized letter
to 585-381-2940.
That's it. It's simple.
We can't offer any further assistance on lost combinations or products not purchased from Office1000.com
If you made a purchase from Office1000.com (a Sentry Safe or anything else) and you need help, please use our customer service form and include your order number
Jul 20, 2009 | Home Security
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Home Security Logo
42 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
