Question about ASUS Computers & Internet
Upgrade affect warranty?
I want to upgrade the ram in my Asus X53L notebook. The notebook is still under warranty- would a ram upgrade negate or affect the warranty?
Thank you
Valerie
  • kiwiyumyum May 09, 2009
    Unbelievable!! You guys are soooo prompt & helpful.
    Thank you thank you from New Zealand :)
    Valerie
    President:
  • 788 Answers
A ram upgrade will not affect your warranty. The RAM is one of the items that the manufacture allows the user to replace. You are good to go.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
Posted on May 09, 2009
Asus x202e repair manual
From what I see the laptop just came out January 2013.
I don't see instructions in the User Manual about how to replace/upgrade the Harddrive, or Ram Memory.
What I do see is the Base Cover comes off to access the above.
Remove AC adapter (Charger), and Battery, turn laptop bottom side up.
Remove all screws going around the outside bottom of the Base Cover, and the one in the middle.
http://techreport.com/gallery/24150/asus-vivobook-x202e-notebook-reviewed/62790/big_bottom
http://techreport.com/gallery/24150/asus-vivobook-x202e-notebook-reviewed/62794/big_guts
At least that's the way it looks to me.
It is covered under a warranty for a year, from what I read.
Why disassemble? Add more Ram Memory?
Replace broken touchscreen? No parts available yet IMHO.
Post additional questions in a Comment.
Regards,
joecoolvette
http://dlcdnet.asus.com/pub/ASUS/nb/X202E/E7620_eManual_S200E.pdf
Feb 21, 2013 | ASUS VivoBook X202E-CT009H Touch Laptop, 1...
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
Ram Upgrade
Yes, you can increase the RAM of your Asus X53L, but first, please review/check the product manual of your laptop on what type & maximum capacity of RAM will its motherboard can support & compatible. Any Brand of RAM will do as long as your laptop motherboard is compatible wih & can support its capacity, this is being made to ensure best operations performance of PC. regards
May 12, 2009 | Computers & Internet
Upgrade Ram - what do I buy?
This is what the spec says. - DDR2 667 MHz SDRAM, 2 x SODIMM socket for expansion up to 2GB SDRAM
If your computer currently have 1GB of RAM. Its high possible there is 2 sticks of 512mb in there right now. so you will need to get 2 1GB memory since you will need to take out both of those sticks to put in these 2. There is only 2 slots.
May 09, 2009 | Computers & Internet
Where is the expansion slot for the RAM for ASUS Notebook A2400H?
The manual is incorrect. Memory is under keyboard. There is a small hole to the left of the right speaker. insert a paperclip vertically into the hole and apply a slight amount of pressure at the same time sliding the plastic section to the left. It should be obvious at this stage. then fold back keyboard. 2 memory slots are located under the plate near the middle of the unit. Specs say max of 2 x 512MB modules. they are PC2100 DDR266 200 pin SODIMM. If there is someone else reading this maybe they can tell me what the slot is for under the smaller plate to the right of the memory compartment.
Cheers.
Aug 06, 2008 | ASUS A2H (A2HOB) Barebone
Asus W1N notebook ram upgrade
Try looking for a small hatch that has a screw holding it in. Should be on the back
May 26, 2008 | ASUS W1N (W1NCOMBO) Barebone
ASUS Ram Location
look in the manual on page 16.shows where its located.
http://dlcdnet.asus.com/pub/ASUS/nb/A2H/e1309_a2_hw.pdf
Apr 04, 2008 | ASUS A2400H Notebook
RAM upgrade for Asus AR9p notebook.
ASUS has a great website and it will have the directions listed under the model of your system. They have everything that you will ever need there.
Rate me as FIXYA if this helps.
Apr 03, 2008 | ASUS m6n Notebook
Ram upgrade
most laptops have a compartment with a led held by a screw on the bottom of the laptop, look under there, typically 1 or 2, RAM and/or Harddrive
Jan 13, 2008 | ASUS m6n Notebook
Computers & Internet Logo
186 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
