Magnavox wmd200f laser moves when starts but disc just barely does every time laser comes back down and it says it cant read disc
This old dvd player a magnavox wmd200f pulled it out today and wont play eye moves back and forth like optical PU is working but disc just wont spin not even manually
    Top Expert:
  • Televison & ... Master
  • 35,672 Answers
The player mechanism has failed.
Posted on Nov 28, 2013
SOURCE: Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
Posted on Dec 29, 2007
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Posted on Sep 03, 2008
epik559
  • 44 Answers
SOURCE: Is a Magnavox MWR10D6 DVD Recorder codec or driver needed to play DVD disks on computer?
There are work arounds... but the reason is when its burnt and finialized its written in .vob format which is dvd mpeg2 format. majority of windows media player codecs wont pick it up. divx does. its just the format its burnt in and you cant change obviously. you can just try like nero showtime which always works or ending up ripping the disc on the computier but that might defeat your purpost of burning them in the first place. Its not the dvd recorder i may add, its just the format. by the way its a magnavox unit made by funai... www.funai-corp.com/support and trust me your not going to get much out of their. your better off going into forums finding more high depth problems if you really want this to work for firends and families and such.
Posted on Oct 31, 2008
SOURCE: DVD will not play in othet players
Look at page 44 thru 46. The disk must be finalized.
Posted on Sep 23, 2009
  • 132 Answers
SOURCE: my magnavox dvd stopped playing.
The lens only the laser may need to be cleaned that reads the dvd. That's what I would try first. Also, make sure the dvd is clean and not scratched too bad. If neither of these are the case, then you probably have a bad
Posted on Jul 29, 2010
Magnavox MPD850 dvd player won't play, only display no disc
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer read the disc, but you can buy a DVD cleaning kit that might breath more life into the player, if no! cheaper to replace the DVD player.
Mar 17, 2012 | Magnavox Televison & Video
My blue ray player will no longer play regular dvd's. I looked for firm updates but did not find any for my model player. What else can I do to fix the problem? Thank you.
Hello
This fault is not with the firmware but with its Laser Pickup Unit itsef. In Blu-Ray players, there are two eam intensities for laser pickup unit, whic are independent to eacch other. One lower intesity beam is used for reading DVD/CD etc and the other is for reading Blu-Ray discs. Although these two beams are comes from the same laser pickup unit, they are generated from two different lased LEDs inside, and each will energize according to the disc we insert into it. In your set the lower intensity laser diode is faulty now. Therefore, the set will read and play Blu-Ray discs, but not others. Repalcement of the Laser Pickup Unit is the only way to rectify this problem. It will be best to get it repaired by the authorised service center for Magnavox, because; exact replacemt type is necessarey, and sometimes it will be difficult to get it from open electronic sparepart market. OK.
Jul 02, 2011 | Magnavox NB500MG9 BluRay Player
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
My DVD player / recorder keeps kicking out the discs I put in. It won't even read them. the screen says close and the tray comes back out almost immediatly. Now it's gotten so bad that the tray won't come...
How old is your DVD recorder/player?
It sounds like it needs a service!
The usual problem with DVD players/recorders not reading discs is that the laser output is starting to fail - and consequently the laser light emitted is insufficient for the system to "read" through the minute "holes" in the disc.
It's possible to have the laser replaced, but this would cost you at least £50, depending on where you live.
Initially, you could try buying (or borrowing) a laser cleaning disc. These cost around £3 to £5 depending on where you buy & live, and have a small brush on the lower side of the disc. Insert this into your player and run the disc for a couple of minutes. If there are any dust particles that have been blocking the light output from your laser head, then this may remove it and might solve the problem.
If this fails, then it seems likely that the laser head is not producing enough output and would have to be replaced with a new one.
Also, you could try playing a CD on your DVD player as these discs contain far less information than a video disc (DVD) and the laser head may be able to cope with this.
If the CD plays ok, then you will know that the reason why it won't play DVD's is the light output has started to fade due to the age or excess use of your system.
Nov 17, 2009 | Sony Televison & Video
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
My dvd player Samsung DVD-R135 will not read any disc, is there any thing that I can do to fix this issue? Thanks! Prasad DVD player will not read disc
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Sep 06, 2008 | Samsung DVD-R135
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
