Question about Goodman GMS90703BXA Heater
Too much flame on Rinnai Pilot light
I just replaced the pilot tube on a Rinnai 2001 heater. Now when I light the pilot I get a huge flame. Can anyone help?
  • andycap1 May 13, 2009
    Many thanks for the advice. It was spot on!
  • Anonymous Mar 18, 2014
    I CANT TURN THE KNOB MY RINNAI MODEL 2001 GAS HEATER FAR ENOUGH AROUND TO LIGHT OR EXINGUISH THE PILOT, NO MATTER HOW HARD I PUSH DOWN. ANY CLUES?
    Novelist:
  • 189 Answers
On the end of the old pilot tubing there should be a small part. This "oriface" would have been inserted inside the pilot assembley in the same hole that the pilot tube screwed into. This small oriface has an extremley small hole in the end that reduces or restricts the gas pressure down to the low volume needed for a pilot flame. I bet that when you removed the old pilot tubing this oriface fell on the floor and rolled under the furnace. Find it, clean it and reinsert it. You will be fine. If you cannot locate it. You will need to buy a new pilot assembly. They come with a new oriface already installed.
Good luck..........
Posted on May 09, 2009
I have a rinnai 30000 btu floor heater. The pilot will not stay lit. I have installed a new thermocouple please help
Contact rinnai support ,make sure the pilot sensor is sitting in the flame,& i hope you did not over tighten it when installing it also lightly sand the end that screws in.
Feb 21, 2015 | Rinnai Heating & Cooling
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
RHFE Rinnai 551FT gas heater is not working after 7 years
see this steps and fix it. God bless you
If there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below).
If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
To light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps:
Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Sep 30, 2012 | Heating & Cooling
Pilot light goes out when heater shuts down
Check the position of the thermocouple and if there is one make sure it is very close to the pilot flame Usually when a pilot light will not stay lit, it is an indication that the thermocouple is bad. Replace it.
Feb 10, 2011 | Rinnai Vent Free Gas Heater/
On my patio heater the pilot light will light but goes out as soon as I release it, even after holding it down a long time. I can't get it to stay on to light the heater.
Check that the pilot light is directed at the thermocouple, a copper 'tube' that heats up when the pilot light is lit. You should be able to see a copper coloured small tube that the pilot light is directed at - if the pilot flame is not heating that tube then the main burner will not light.
If the thermocouple is being heated correctly, then it could be a fault with the thermocouple itself (can be replaced) or the gas valve.
If the pilot flame is not heating the end of the thermocouple you should be able to adjust its position so that the pilot flame is directed at it more accurately
Jan 18, 2011 | Rta International Patio Heater
Pilot light wont stay on. How do you adjust pilot flame? Pilot flame doesn't reach temperature sensor.
then the pilot is blocked needs cleaning out or try blowing it out with air , or undone pilot and remove pilot injector and clean it .
Nov 01, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
The pilot light on the Rinnai gets blocked with
the heater needs service /cleaning along with the pilot to findout why this carbons up
May 12, 2010 | Heating & Cooling
NO HOT WATER N THE PILOT NOT LIGHTING UP
The thermocouple has gone bad.The thermocouple needs to be directly in the pilot flame.When the thermocouple goes out,the flame most of the time will have burned the thermocouple tip a way.If it was not for this devise,the gas would exscape,and fill the home up.This is a safety feature.
Oct 20, 2009 | Heating & Cooling
Pilot light won't ignite on a Rinnai 2000 1
The trick is that it may take a long time for the flammable portion of the gas to reach the pilot light orifice where the flame lives. This happens a lot when the pilot flame has been out for some time. There won't be a clicking sound as YOU are supposed to provide the flame - it's not like a cooking stove with such conveniences, because the pilot light is only an occasional thing to light it's rare to find an ignition source built in. I'd hate to see you spend good money when all you need to apply here is time and a flame.
Sep 06, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
243 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
