well it looks as though you have been moving plenty of computer parts and leads around double check that every lead has a secure seating including electrical extensions from motherboard to hard drive or even replace them with new ones
make sure all of your drives are working computers need all power and data to travel through every working device and to have an end point to be able to work properly
make sure ram modules are clean and are securely seated and the ram sockets are clean and cmos battery is securely seated some motherboards cmos batteries are soldered in make sure CPU has thermal paste and a dust free secure seating
Must have messed up the CMOS reboot sequence. Enter the CMOS menu screen. Go through the menus and look for "Boot Sequence", and set this to your primary HD for now. Once you get your system up, you can change the Boot sequence to CDR first, followed by HD.
u have to reset your bios settings.
open your bck side of laptop remove battery also refix ram. then u see 1 cmos cell on motherbord. put away it for 15 mnutes then refix.then check .u can do it friend.
after rthat check your key bord numlock key if your num lock is on and off your cpu is ok and your monitor haas pro.
other wise check your ram clear it and fix exactly in its position.check your processor refix it . clear your bios setup take away your cmos cell for 15 minutes then fix it.also try cmos jumper to reset it
well can ya give me some descrition how do u get blue screen probably by running any game or wat? if yes reset cmos install window again then the problem mite b solved if still its not then u myt have sum hardware problem!
