Question about Canon imageRUNNER 1600 Laser Printer
Kyocera fs-1016mfp error code 1600 service call
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Feb 02, 2011 | Kyocera FS-1016 Printer
How can I resolve kyocera fs 1016mfp error 6000? thanks
Causes:
Follow the flow chart:
Turn power switch off, and
remove power cord.
Detach YC7 connector on
the engine/high voltage
PWB.
Measure resistance
between pins 1 and 2 of
the detached connector.
Open
(infinite)?
Yes ---> Replace the fuser thermistor.
NO ----> Detach YC1 connector on the power source PWB.
Measure resistance
Open
(infinite)?
Yes ---> Replace the thermal cutout or heater lamp.
NO ----> Replace the engine/high voltage PWB.
Sep 01, 2010 | Kyocera FS-1016 Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Call service 7410:0100539 on a Kyocera fs2000d
I have heard that 7410 is a standard code meaning the drum is out of position. Seat the drum correctly and away you go.
David
www.copycare.net
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Canon imageRUNNER 1600 Laser Printer Logo
24 people viewed this question
old marine
old marine
