Question about JVC Televison & Video
Jvc av 29x56sat no power at secondary
I almost change all parts in primary and secondary but still no power ,,then after i disconnect secondary low voltages the b+ went out but if i solder again the b+, no more power at all
    Top Expert:
  • JVC Master
  • 74,118 Answers
There should be a short circuit at its +B side. Just disconnect all the load from the +B, connect a 100W 220V filament type bulb [Not CFL or other type], as load, and switch the set ON. If power supply is OK, the bulb should glow with half its intensity.
If it does so, check the horizontal scan output transistor, which drive the LOT (Will be screwed to a metal heat sink), for any short. De-solder it out from the circuit, and switch ON the set, after connecting the +B voltage; and now measure the +B voltage. If it is found OK now, be sure that the horizontal output drive transistor is leaky, should be replaced. To get more details, http://electronicshelponline.blogspot.com/ If you wish to get further assistance from me, come over by Fixya comment. OK. Good Luck.
Posted on Nov 28, 2013
3 Suggested Answers
  • 556 Answers
SOURCE: JVC TV- MODEL AV-K21T.
it was not necessry to replace so many parts if you go as per proper procedure.please proceed as 1 isolate horizontal output section from power supply & make power supply ok. 2 if it becomes ok check hor osc,driver&h/output section. 3 if it is ok connect power input to hor.section which was isolated. 4 check for loose contact or print. 5 put on tv .
Posted on Sep 22, 2007
yambo
  • 230 Answers
SOURCE: jvc will not power up
Not, just install soldering stations on the terminal capacitor ( bottom) and pull up slow, clean solder and put it back new one. See position ( -- And + )
C926 and C928 1000uf 35v Common problems.
Some time D905 shorted
Replaced C911 470 uf 35V
Ready!!!
Posted on May 11, 2008
Jvc tv model av dx25,power on but no raster and sound
if you want to do it with your own, you will need a proper trouble shooting. which need the right device and tools to do the job and make sure you have at least a basic knowledge in electronic repair. the first place to be check will be the power supply section, you need to have voltage checking weather their is a secondary dc voltage from the power supply section going to the horizontal section. to turn on the other circuit and the flyback transformer. you have to know if their is a 135dc voltage at the power supply section,check at the primary capacitor using a digital tester.
Nov 28, 2012 | JVC Televison & Video
Onkyo AV Receiver HT-R500 No power whatsoever, no illumination of any display options and no activation clicks upon pressing the power button! We inspected the receiver via dust cover removal and found no...
If that is true the power transformer is probably open at the primary, the secondary voltages feed the receiver and power various parts. I suggest getting it checked, my worry is the power transformer may not be available from the parts manufacture.
Mar 28, 2012 | Onkyo Audio Players & Recorders
Have model # AV-20220 front red power timer light flashing but tv will not come on when power button is pressed.
this sometimes indicates a dead or defective secondary power supply,have a certified tech for servicing
Jul 18, 2011 | JVC AV-20220 TV
Left overnight truck wouldn't start. with charger on it ok, but left standing for 4 hours, no start. Changed primary battery still same. disconnected both negative terminals overnight and today both...
Your battery may have a dead cell, take it out and test it, use a charger and a volt meter, after the charge if the volts are still low then replace it, or you could take it to a parts store and have them test for the dead cell.
Jan 18, 2011 | 2007 Ford F-350 Super Duty XLT
I'm not getting any low voltage at the t-stat.
Make sure that the transformer has power on the primary side then check the secondary side for low voltage. If you have power on the primary and none on the secondary then replace the transformer.
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Sanyo tv model no. ST-21G1 power indicator is just blinking it does not oscillate the horizontal output. what is the possible problem or parts to be replaced?
Check if Horizontal ouput is shorted.Check if you have B+ (135VDC) power supply and secondary supplies working(12VDC, 5VDC) and check if you have horiz. drive pulse from drive transformer.
A common fault for dead set is the capacitors in the power supply (secondary of transformer) - no 12VDC supply.
Oct 22, 2009 | JVC AV-27950 27" TV
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
Does not power on. Q951 charred
you can look for the model and brand, look for it on the internet and see if you can have the schematic diagram, you're lucky if u can. Lightning will strike first the tuner side, if there is a red blink, the primary side may be okay in switching type regulator, just replacing the charred part may not solve the problem. look for shorted components on the secondary of the power section.
May 15, 2007 | JVC AV-32230 32" TV
JVC AV-26BM4
replaced the capacitors(electrolytic) in the primary area of ps.visually check for dried up. also replace the starting resistors in primary ps common values are 100k to 820k .hope this help u....
May 09, 2007 | JVC TM-A13SUW TV
Televison & Video Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
