Question about Technics SA-AX710
Technics sa ax710 overload - Technics SA-AX710
4 Suggested Answers
SOURCE: receiver
My SA-AX710 overloads intermittently. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
Posted on Jun 14, 2008
seabelow
  • 95 Answers
SOURCE: Overload on Technics SA-AX710 Receiver
Turn it off...remove all the speakers and turn it on....If it goes into the protect mode. you have a bad power amp. That's the big black flat things attached to the cooling fins.. one or both is shutting the system down. If it doesn't trip out, plug a head set into the phono jack and see if you can hear the music there. Can you turn it up without tripping.... if it's still ok...hang one speaker on the system, if it trips thats the bad leg...check the speaker/wire
Posted on Oct 23, 2009
Grubhead
  • 5193 Answers
SOURCE: on switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Posted on Mar 09, 2010
It keeps saying overload whats that mean
you have a blown or shorted speaker, or you have a blown input/output in the unit.
Look up my tip on transistor checking, and look for bad capacitors too.
Mar 04, 2011 | Technics SA-AX710
Our SA-AX7 says overload. What do we need to do?
Do not continue further. There is a short circuit in the power supply or output amplifier stage. Disconnect power. The unit is preventing a fire or further damage to the system. Also, check the speaker output terminals for wires shorting the terminals together. Otherwise, an audio repair shop must isolate the problem. More than likely a transistor has shorted in the output stage.
Nov 12, 2010 | Technics SA-AX710
When someone stomps or base hits back right surround speaker crackles also overload comes up and system cuts out
There's a loose connection somewhere. Follow the speaker wire to the speaker. Somethings vibrating and causign a temporary short.
Dec 27, 2009 | Technics SA-AX710
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Receiver
Mar 03, 2008 | Technics SA-AX710
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Nov 22, 2005 | Technics SA-AX710
55 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
