Question about Optoma HD65 DLP Projector
Optoma hd 20 fan lock
Why is saying fan locked
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: hey my optoma hd65 bulb blew so i replaced it and
the lamp probably blew because the fan stopped. if the lamp can't cool down, it blows. you'll have to find out which fan and replace it.
Posted on Nov 16, 2009
davisinsu835
Carefully take the projector apart. Find someone with an air compressor once the cover is taken off of the projector and you can then get to the main fan from both sides. Blow it out as much as possible and make sure to put emphasis on the fan. Re-Assemble the projector and everything should work fine after that. Mine did the fan lock thing right when I put the new lamp in and this fixed it after Optoma told me to send it in for service. I had nothing to lose because I would buy a new projector before I spent that much to fix this one. Truest me it works.
Posted on Jan 18, 2012
OPTOMA PROJECTOR hd25e LOCKED CENTRAL PANEL AND IR DISABLED HOW TO FIX
Your problem same like me,just hold on the ENTER button 7 second and than press the SOURCE button,the projector will auto reset.
Dec 17, 2014 | Optoma Office Equipment & Supplies
LG DLP projector fan lock problem
hi, i have fan locked problem on lg projector.
Apr 23, 2012 | Optoma HD65 DLP Projector
Optoma hd20 fan shut down
I put this here because when I was experiencing the same issue I found there was very little info online for this topic. Optoma asked me $125 just to take a look at my out of warranty hd20 projector after I started getting the dreaded "fan failure" error message, I got this error mesage after replacing the bulb (its important to note that the bulb did explode in the unit so some of the debris may have lodged in the fan.) Optoma also kept saying stuff like motherboard issues and fan sensors on the phone. Everything I've read has said the repair price is so high on these issues that it is better to upgrade to a new projector so I resigned myself to doing that very thing. Then I ran up on this video and thought what the heck. So I took the plunge and popped the case off and sure enough the same little fan was stuck and covered with dust. I gently moved it with a screw driver and blew all the dust out of it. Plugged it back in and I'm experiencing glorious 135" hd once again.
Feb 28, 2012 | Optoma HD20 DLP Projector
HELP!>After replacing a new bulb, I turn it on and 3 seconds later it said Fan Locked and turns off. Any ideas? Thanks
Hi sir
firstly try to clear the induction of color wheel,
if it still happen same hint, perhaps the fan was failure.
hope i can help you.
regards,
Jack
wanminjun@gmail.com
professional whole saler and retailer for below products:
most of brand projector spare parts: lens, color wheel, bulb, mother board, etc. match for Benq,sharp, optoma, samung,dell, etc.
HP server, router, switch,
computer motehr board, hard disk. DELL, IBM, ASCUS, Hp etc
Nov 10, 2011 | Optoma HD65 DLP Projector
Warning: fan locked contact service center for
di pasang kipas baru tapi masih bertuliskan warning fan locked terus mati..projektornya
Jun 23, 2011 | Optoma HD65 DLP Projector
I get the message of fan failure in my optoma hd 80 home theater projector, is it fixable, needs a replacement fan, etc.?
first vac and clean vents for proper air flow if still coding with unit unplugged remove cover and check fan for blockage if good and still fan code test fan, if bad fan is replaceable most electronics or some computer stores should have it if u want to diy can use serial&model number of projector or numbers on the fan
May 18, 2010 | Optoma HD80 Projector
Optoma HD 70 turns on with lamp and temo soiled lights
Asher fadida and alll,
The issue:
solid red error light?
HD70 "die's" after few min with strage noise?
flickers different colors before complete self shutdown?
well try this....
Before replacing your bulb, fan or any other component try first cleaning your optoma realy good!! HD70 doesnt comes with any kind of filter so you can imagine the amound of dust can be.
The most importent thing is to blow away any dust from your color wheel + the sensor attached to it .
for farther troubleshoting clean your fan's.
there are 2 fan's insinde the HD70.
probably the most problems will be solved by cleening the color wheel!!
if the problem is not solved ,chack the lemp and the fans if they work properlly.
For fan replacing:
Fan Part number: GM1207PKVX-A
Good luck!!
Feb 23, 2010 | Optoma HD70 DLP Projector
Hey my optoma hd65 bulb blew so i replaced it and when i powered it back up i received the fan lock error
Nov 07, 2009 | Optoma HD65 DLP Projector
Optoma HD65 DLP Projector Logo
18 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
