Question about Dimplex Heating & Cooling
How do you operate the heating for dimplex DC10RC
We cannot get the heating to work on the air conditioner DC10RC
  • 726 Answers
SOURCE: AIR CONDITIONER NOT OPERATING
sound like the thrmostat has stop working thats the only thing that could be wrong
also try cleaning any filters the unit has
Posted on Jul 07, 2008
SOURCE: E4 error message on Dimplex portable air
Ensure water emptied
Posted on Nov 02, 2009
SOURCE: During heating (outside temp. 2 deg C), outside
Get the charge tested, check the sub-cooling across the outdoor coil.
Posted on Dec 19, 2009
hvac1960
  • 2133 Answers
SOURCE: Dimplex portable air conditioner Model
E-1 Refers unit indoor room sensor defective. Replace it.
Posted on Jan 06, 2011
hvac1960
  • 2133 Answers
SOURCE: i'm getting an E3 message
E-3 Indoor fan motor mechanism locked. Check fan motor for bearing. If F.M is good, problem with PCB.
Posted on Jan 16, 2011
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Heat and air unit heat stopped working
1-Check Thermostate for setting may wrong or Th. faulty.
2-Fuse near to heating element blown, Change it.
Nov 12, 2013 | LG Electronics 23,500 BTU 230v Window Air...
Air and strips work but heat won't
Check that the reversing valve is not stuck. TAP on it with the plastic end of a screw driver while the system is calling for 1st stage heat. Check low voltage wiring at outdoor unit from t-stat.
Nov 08, 2013 | Goodman CLQ36AR49 Air Conditioner
Wife kicked on heat this morning, worked fine. turned off before leaving for work. now we have nothing. heat or air. thermostats runs a heat pump plus the air. thinking it`s got a bad swich. oh, it`s 21...
Here is a tip about troubleshooting your air conditioner or heat pump...
There are many things that can cause your air conditioner not to cool or heat...
Air Conditioner Trouble - Review the Possibilities
heatman101
Apr 22, 2011 | Heating & Cooling
Heat quit working- air still works
Please check the following:
1. Mode"Heat" 2. Temp setting +29. 3. Heating sensor.
Dec 10, 2010 | LG Heat cool Window Air Conditioner
Air conditioner works fine but heat won't kick on
Check RV is working. And also keep thermostat setting +29 and heat mode.
Dec 09, 2010 | Ruud Matching Split Air Conditioner
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
GE zoneline - about 23 years old
theres a heat relay and also the wire used for heat.either could be bad.
Nov 05, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Feb 25, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
