Question about Home
Flip over bathroom plug in bath stuck & bath full :/
Cannot get enough pressure to flip plug. Would a plunger help? Difficult to access under bath. Sounds gritty. Possible build up of cleaning product residue?
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Remove the shower head from the pipe.
  2. Clean the arm threads and wrap them with plumbers' joint tape.
  3. Screw the head back on and hand-tighten it. Remove any excess compound or tape.
  4. Test and retighten as needed.
Repair a shower head that leaks at the swivel:
  1. Unscrew the shower-head body from the swivel-ball ring.
  2. Find the O-ring or a similar seal inside. Replace it and screw the shower head back into place.
  3. Turn off the water supply and open the faucet handle to relieve water pressure.
  4. Carefully loosen the coupling nuts at the shutoff valves and at the base of the faucet.
  5. Carefully remove the supply tubes.
  6. Remove the locknuts that hold the faucet to the sink and lift the faucet out.
  7. Clean the area where the old faucet sat.
  8. As needed, install the new spray hose and supply tubes, if any, through their holes in the sink.
  9. Set the rubber gasket that came with the faucet on the sink where it will be mounted. If no gasket is supplied, apply plumber's putty.
  10. Set the faucet into position and center it.
  11. From under the sink, attach the faucet locknuts to hold it to the sink.
  12. Reinstall the supply lines, then turn them on and test the faucet. Turn it on carefully because the line and faucet have air in them.
Posted on Nov 28, 2013
Testimonial: "Thank you for your reply. However the problem I have is with my bath plug not my shower. Thank you for taking time to offer help though."
CLEAR A/C DRAIN
Try blowing compressed air up the pipe from under the car. Or push a light piece of wire up it. It will take a long time to do it from inside. Regards Jim...
May 19, 2015 | 2010 Cadillac DTS
I have a glass bowl sink in my bathroom. The pop-up drain is stuck in the down position and will not release. How do I fix it??
You'll need to access back side of sink bowl and locate drain mechanism, most likely either the plunger rod has loosened up from clevis rod or clevis rod is positioned to far in towards drain line causing it to bind. Check diagram for assistance in locating parts.
Is the plunger rod tight or loose? You can also loosen clevis screw and see if the plunger rod will slide freely. If it does try moving the horizontal pivot rod up and down, while doing this you should she your drain plunger moving up and down. If it does not then most likely will need to replace plunger mechanism by removing the retaining nut on the back side of the drain line. This will allow you to disassemble the actual drain plunger but I would definitely start with the mechanism of the stopper and clevis where it attaches to horizontal rod.
Sounds like a simple binding. Always be sure there isn't anything stored under your sink which could be causing the problem. Sometimes the most obvious is the last thing we look at.
Good luck.
Aug 16, 2013 | Pegasus Technologies Pegasus Clear Round...
Should i use the same drywall in the bathroom as in the rest of the house?
I recommend using MR (Moisture Resistant) drywall for the bathroom, and possibly for the basement if there are moisture issues. It is not much more expensive, and it can save you a big headache later
Jan 16, 2013 | Drywall
My favorite framed painting is stuck to the glass and will not come up without leaving parts of the painting behind on the glass
Take the glass its stuck to into the bathroom next time you bath or just leave it in there and turn your shower or bath on full hot get the room really steamy and set it as close as possible to the source of steam. Leave it in for a while it will loosen up.I've done this 4X.
Mar 10, 2012 | Audio Players & Recorders
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
Removing bath drain
There are two types of tub drain stoppers for the delta brand - lift & turn and toe tap.
Lift and Turn:
The lift & turn stopper for the bathtub unscrews counterclockwise while in the full up position.
Toe Tap:
The toe tap stopper does also but if the cap may unscrew from it before the entire stopper comes out. In that case, there is a nut that is now exposed and can be accessed to unscrew the assembly.
If either of these is "spinning" without unscrewing, the threads are stripped and you would need to exert upward pressure while unscrewing in hopes of uncoupling this from the bath waste. If that doesn't work you would have to unscrew the bath waste flange from the drain pipe.
This will require access under the tub. I hope this answer the question for you. Thank you for using FIXYA. Jeff
Apr 09, 2010 | Delta Home
Pressure to low
there might not be a large enough pipe suplieing the shower or bath room i would have 3/4 pipe at least to that bathroom. body sprays need alot of water
Oct 23, 2009 | American Standard R125 Pressure-Balance...
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Electric supply to whirlpool bath
remove box then put through wall put it back on other side
Feb 21, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Jan 31, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Home Logo
219 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
