Tv fault finding
Audio k, video should be not come only blue color screen with horizontial lines are came...some times power off then ON the Tv video and audio working properly..i think some loose contact pls help me..
  • Ganesh
    Ganesh Nov 28, 2013
    Hi Ganesh , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Ganesh
    Ganesh Nov 28, 2013
    picturetube on yoke wire are not solderd....4 wires are twisted only
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
I assume you might have post this problem under CRT based TV; and not with Flat Panel TVs. Anyway let me post a solution to this. The first thing you have to do is, to solder all the four connections to deflection yoke. It's a must. Never allow any loose contact with these connections. It might lead more troubles. Never switch ON the set, without soldering these connections well.
Then comes, the case of raster. If there is only a blue raster, with horizontal lines, as you describe here, it should be the fault with its video output stage circuit itself, provided CRT is good. If the horizontal lines displays at equal space, that is, at about an inch space, all around the screen [white thin lines], and are some what parallel to each other, check the voltage at the blue cathode of the CRT base. If this voltage is very less than the other two cathodes, check the blue video output transistor's collector voltage. Check the transistor for collector-emitter leak. Replace it. Check its collector voltage. If found very low, check and replace the load resistor connected to it collector to video output supply voltage [180VDC].
I think you to be somewhat sound in elelctronics, and is why I spend some time to place this solution here. For more information go to http://electronicshelponline.blogspot.com/. Pull up older posts. Hopes it will help you. Good luck.
Posted on Nov 28, 2013
  • The Knight
    The Knight Nov 28, 2013
    Check for any loose solder terminals at the CRT base socket. Re-solder all these solder terminals, by applying a little more solder.
SOURCE: No video
Possible bad main board or panel.
Posted on Sep 07, 2007
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Posted on Oct 23, 2007
hawkwatcher
  • 67 Answers
SOURCE: Zenith LCD Flat Screen TV just shows vertical lines of color
Press menu button on the TV if the on screen display is also distorted or no pic the TV is definetely defective. You can try unpluuging from wall for about 15 minutes and see if reset helps if not problem is either main p.c.b , LCD panel , LVDS cable or Power supply board. and would require service. most likely problem would be bad connection at or defective LVDS cable that connects main p.c.b to Panel (cheapest fix) or defective main p.c.b. If it is the panel it would probably not be worth repairing and you may want to sell as is on ebay.
Posted on Jan 13, 2008
SOURCE: Haier TV model 42HP25BAT
I have the Haier plasma..Model # 42EP24S and as others it has went to a black screen with only audio...Is there something I can do to fix this....Thank you for all help. Alison
Posted on May 05, 2008
premtech
  • 934 Answers
SOURCE: LG 37LC7D
Howard,
Do not keep forcing this unit on - - This particular unit has a VERY commonly known problem and there are at least five tech bulletins from LG explaining this and other symptoms for the failure. In a nutshell there are coils that have to be removed and replaced with a jumper wire. This is not a repair you want to tackle so please get some experienced help for this one. A good technician will look-up the bulletins and educate themselves on the manner of the repair.
Almost all of the symptoms that can happen are intermittent and can be extremely difficult to verify. For this reason make sure to discuss with the technician that he replace all of the coils listed in the bulletin not just the ones causing your particular problem. Here's a list of symptoms that these defective coils cause, taken right from the bulletin:
1. Channels Or Menu Functions Scroll On Their Own
2. Remote Does Not Function
3. Tv Randomly Powers On And Off On Its Own
4. Dead
5. No Backlight
Hope this helps!
William Rayburn, CET
Premium Technologies
Posted on Aug 03, 2009
Blue haze and blue lines. no true black color
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2011 | Sony KP-57WS500 57" Rear Projection...
Cant get the blue convergence to move on tv, has a bad blue shadow
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 26, 2011 | Samsung PCL5415R TV
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
Screen looks bent and color is out of line
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Multi color jagged line across screen
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 12, 2011 | Philips Televison & Video
Colors in left upper corner like a rainbow and fuzzy warped picture with lines that will run thru the picture from time to time, majic focus does not clear this up and I can not get the color set...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 06, 2011 | Hitachi 50SBX78B 50" Rear Projection...
The picture is kinda wavy and the three different colors are off set
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 09, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Green and blue shadows on the screen
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 30, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Blue streak across the top of the television and colors are reflecting making it look 3d
•Screen looks 3D
Jun 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
