Question about Refrigerators
Compressor problem or?
Ok, I imagine the answer to this will be pretty simple. I have a prolux fridge/freezer (possibly also known as beko) which clicks and buzzes for a couple of seconds before cutting out. It doesn't therefore cool, and cyles again a few minutes later with the same result. I replaced the capacitor because it was easy to source. I attempted to get a relay but I am struggling to get the right item as it is discontinued. I have opened the old solid state relay and inside seemed ok.o I did not attempt a test on it however as I only have a multimeter. On the outside it was slightly discoloured (brown ish) but possibly was ok. Obviously now its been prised open it's gonna be useless. The more important information - which is probably the most important question I have - is across the compressor terminals I get readings of 11, 10.5 and 4.9. These obviously don't add up in the way they should. Is this an indication 100% that it is shot? Will getting a hard start 3-1 thing be worth it? They are impossible to find locally and therefore purchasing one from the US will cost with postage about 15 uk pounds. Not loads but throwing good money after bad? I can purchase a 2nd hand fridge freezer with a limited guarantee for about 60 to 70 pounds. The compressor does not show any 'continuation' from pins to the body of the compressor. I think that at least is a good sign. So what about the readings. I know the 2 lower should add up the highest value. What do my readings tell you experts?
  • 3 Answers
I say what is key
Posted on Nov 28, 2013
4 Suggested Answers
  • 833 Answers
SOURCE: Refrigerator buzzes & clicks
The only thing a capacitor does is 'kick' the compressor to start it. There is a box on the compressor containing the start relay. If it is defective or dirty, it might buzz. With the power off, find it, remove its cover and use some canned air to blow off any dirt inside. If that doesn't fix it, replace it. If there is a fan down there, be careful...and be sure it is working.
Posted on Dec 23, 2007
SOURCE: clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Posted on Apr 27, 2009
  • 10 Answers
SOURCE: I have a ARB2205CS that is 6.5 yrs old. It stopped
Yes your compressor is coming to a stop. There was a 5yr warranty I am sure but if it's 6.5yrs now it's still beyond coverage. I would call some authorized companies familiar with these models who replace the compressors. Not all companies do. Shop around for the best price. I am sure you can do better than $700. I can usually compete that job in 1.5hrs. And the replacement is a great compressor.
Posted on Jul 01, 2009
Hi. Why has my Beko fridge freezer ceased freezing. Fan & light still function.
compressor is running? u can hear it? may have a freon leak? or check the defrost timer or cold control thermostat, some freezers have a freezer thermistor may have gone bad can check all with a multi meter
Mar 10, 2015 | Beko Refrigerators
Compressor problem?
It is good that you know how to use multimeter. I am not an expert in compressor but I think it should involve a motor. When the compressor is running, it should be supplied with close to powerpoint voltage. I am not sure what your powerpoint voltage is as I don't know which country you are in. The reading you gave were not quite close to powerpoint voltage (I thought it should be in the range of 110V to 240V). If it is a transformer, the voltage should add up but I am not sure about compressor. See if you can provide more information.
Nov 28, 2013 | Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Fridge temperature not correct and freezer items are all defrosting. This also happened a year ago, except it was just the freezer and the fridge freezer is only 3 years old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Beko Refrigerators
I have a BEKO CDA539F and notice that there is one with an X attached to the end of the code that is amongst the recall models. I asssume that my fridge freezer is safe. Am I correct?
From what I understand, you are safe if your serial number does not match the ones in the list exactly. That said, the information I have is from knowledgeable sources but NOT from BEKO, who have failed to answer their 0800 incident line or reply to my mails for 4 days now (By coincidence, while I provide a lot of technical help on this forum, I also have a BEKO fridge that IS on the list).
I would go to their site and send in a mail via the facility they offer there. I imagine that at some stage you will get a confirmation that all is OK with your fridge, but I would want to cover the bases if I was in your position. For convenience, the original article I wrote with the BEKO website listed in it is reproduced here for you:
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including most importantly, BEKO's own website, the MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
The fridges affected were manufactured between January 2000 and October 2006. After shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008. The first 2 digits of the serial numbers indicate the year of manufacture, so if your serial number doesn't start 00, 01, 02, 03, 04, 05 or 06 you don't even need to check.
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
The site also provides a mail address and a UK Freefone number that you can call (Though I've tried the number and it keeps cutting me off!! I presume they are swamped with calls)
Jul 09, 2011 | Freezers
Beko fridge freezer not working
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem of the freezer...
May 06, 2011 | Freezers
I have a beko ab910 w . the top half of both the fridge and the freezer have defrosted whilst the bottom half of the freezer and the fridge are frozen .
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 20, 2011 | Microwave Ovens
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Hi, I have a Beko fridge freezer. It was delivered flat and when plugged in 24 hours later the freezer seems ok but, the fridge is not cooling the light is on. It's a second hand fridge. Thanks
hi. thanks for the question . Check , the freezer fan motor, to see if its ok. check the coils at the back, and fan at the back . if all ok. check behind the freezer wall to see if all coils are frosting up .If all te coils are not frozen you have a faulty compressor .thanks the appliance doc
Oct 01, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
