Question about Refrigerators
Compressor problem? Ok, I imagine the answer to this will be pretty simple. I have a prolux fridge/freezer (possibly also known as beko) which clicks and buzzes for a couple of seconds before cutting out. It doesn't therefore cool, and cyles again a few minutes later with the same result. I replaced the capacitor because it was easy to source. I attempted to get a relay but I am struggling to get the right item as it is discontinued. I have opened the old solid state relay and inside seemed ok.o I did not attempt a test on it however as I only have a multimeter. On the outside it was slightly discoloured (brown ish) but possibly was ok. Obviously now its been prised open it's gonna be useless. The more important information - which is probably the most important question I have - is across the compressor terminals I get readings of 11, 10.5 and 4.9. These obviously don't add up in the way they should. Is this an indication 100% that it is shot? Will getting a hard start 3-1 thing be worth it? They are impossible to find locally and therefore purchasing one from the US will cost with postage about 15 uk pounds. Not loads but throwing good money after bad? I can purchase a 2nd hand fridge freezer with a limited guarantee for about 60 to 70 pounds. The compressor does not show any 'continuation' from pins to the body of the compressor. I think that at least is a good sign. So what about the readings. I know the 2 lower should add up the highest value. What do my readings tell you experts?
    New Friend:
  • 169 Answers
It is good that you know how to use multimeter. I am not an expert in compressor but I think it should involve a motor. When the compressor is running, it should be supplied with close to powerpoint voltage. I am not sure what your powerpoint voltage is as I don't know which country you are in. The reading you gave were not quite close to powerpoint voltage (I thought it should be in the range of 110V to 240V). If it is a transformer, the voltage should add up but I am not sure about compressor. See if you can provide more information.
Posted on Nov 28, 2013
  • 833 Answers
SOURCE: Refrigerator buzzes & clicks
The only thing a capacitor does is 'kick' the compressor to start it. There is a box on the compressor containing the start relay. If it is defective or dirty, it might buzz. With the power off, find it, remove its cover and use some canned air to blow off any dirt inside. If that doesn't fix it, replace it. If there is a fan down there, be careful...and be sure it is working.
Posted on Dec 23, 2007
aborcass
  • 2651 Answers
SOURCE: buzzing sound, freezer nor fridge cooling
sounds like a compressor issue, perhaps the good news would be if its just under 5 yrs, youll have a 5 yr warr onthe compressor assy.( you should anyway) ck your manual for warr info
Posted on Nov 20, 2008
SOURCE: clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Posted on Apr 27, 2009
  • 10 Answers
SOURCE: I have a ARB2205CS that is 6.5 yrs old. It stopped
Yes your compressor is coming to a stop. There was a 5yr warranty I am sure but if it's 6.5yrs now it's still beyond coverage. I would call some authorized companies familiar with these models who replace the compressors. Not all companies do. Shop around for the best price. I am sure you can do better than $700. I can usually compete that job in 1.5hrs. And the replacement is a great compressor.
Posted on Jul 01, 2009
aasc
  • 1606 Answers
SOURCE: Fridge working but not cooling.
The white component you see , is the problem . That is the overload/relay . These short due to power surges , dirty coils in the front bottom of refrig , or just by age . They short , to save the compressor , when one of these happens . The part number you need is # 8201786 . This part just prys off (maybe one wire clip ) , easily replaceable with instructions included with the part .
Posted on Sep 06, 2009
Compressor problem or?
i say what is key
Nov 28, 2013 | Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Fridge temperature not correct and freezer items are all defrosting. This also happened a year ago, except it was just the freezer and the fridge freezer is only 3 years old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Beko Refrigerators
Beko fridge freezer not working
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem of the freezer...
May 06, 2011 | Freezers
Fridge not getting cold tried making sure drainage not blocked
heatman101
Mar 16, 2011 | Beko TLDA662
I have a beko ab910 w . the top half of both the fridge and the freezer have defrosted whilst the bottom half of the freezer and the fridge are frozen .
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 20, 2011 | Microwave Ovens
BEKO CDA539F Freezer does not freeze, fan seems to work, fridge seems to be at temperature. Food soggy/melted
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 30, 2010 | Refrigerators
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Hi, I have a Beko fridge freezer. It was delivered flat and when plugged in 24 hours later the freezer seems ok but, the fridge is not cooling the light is on. It's a second hand fridge. Thanks
hi. thanks for the question . Check , the freezer fan motor, to see if its ok. check the coils at the back, and fan at the back . if all ok. check behind the freezer wall to see if all coils are frosting up .If all te coils are not frozen you have a faulty compressor .thanks the appliance doc
Oct 01, 2008 | Refrigerators
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
