Question about Sub-Zero 632 / S
Where is the water connection for 632s - Sub-Zero 632 / S
  • Sub-Zero Master
  • 842 Answers
Subzero only had two location for this water connection, either at the top behind the grill or under the unit below the doors. I hope this helps, good luck.
Posted on Nov 28, 2013
How does the cook top come off a psp 632s
http://125.214.74.167/product/documents/westinghouse/gsp625sng_2_UserManual.pdf not sure it wil help but if not I would try to lift the top gently with a putty knife (thin flat) blade tool
Jan 21, 2015 | Kitchen Ranges
I have a 2000 taurus can you show me how do I change the thermostat on my car
3.0L OHV Engine
Fig. Exploded view of the water hose connection and the thermostat assembly - 3.0L OHV engines (click over pic for zoom)
  1. Drain the coolant until the level of the coolant is below the level of the thermostat.
  2. Disconnect the upper radiator hose from the water hose connection.
  3. Unfasten the three water inlet connection retaining bolts and remove the water hose connection.
  4. Remove the gasket and thermostat from the water hose connection. Discard the gasket.
To install:
  1. Clean the water inlet connection mating surfaces.
    NOTE The jiggle valve on the thermostat must be in the up position.
  2. Place the thermostat in the water hose connection making sure the thermostat jiggle valve is facing up.
  3. Install the new gasket and place the water hose connection assembly into position.
  4. Install the water hose connection assembly retainers and tighten them to 89-124 inch lbs. (10-14 Nm).
  5. Connect the upper radiator hose to the water hose connection.
  6. Fill the engine with coolant, start the engine and check for leaks.
  7. Stop the engine and top off the coolant recovery reservoir as necessary.
3.0L DOHC Engine
Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines (click over pic for zoom)
  2. Raise the vehicle and support it with jackstands.
  3. Disconnect the lower radiator hose from the water inlet connection.
  4. Unfasten the two water inlet connection retaining bolts and remove the water inlet connection.
  5. Remove the O-ring seal and thermostat from the water inlet connection. Inspect the O-ring for damage and replace as necessary.
To install:
  2. Install the O-ring, thermostat and the water inlet connection. Refer to the accompanying illustration If you can-t remember how the O-ring and thermostat are positioned.
  3. Install the water inlet connection assembly retainers and tighten them to 71-106 inch lbs. (8-12 Nm).
  4. Connect the lower radiator hose to the water inlet connection.
  5. Fill the engine with coolant, start the engine and check for leaks.
  6. Stop the engine and top off the coolant recovery reservoir as necessary.
Good luck (remember to rate this answer).
Apr 27, 2011 | 2000 Ford Taurus
Where is the thermostat on a 2002 sable?
Try this:
3.0L DOHC Engine
To install:
3.0L OHV Engine
To install:
    Fig. Exploded view of the water hose connection and the thermostat assembly-3.0L OHV engines
    Fig. Remove the upper radiator hose from the water outlet
    Fig. Remove the water outlet retaining bolts and . . .
    Fig. . . . remove the outlet from the engine
    Fig. Remove the thermostat from the water outlet
    Fig. Inspect the water outlet connection for cracks or damage
    Fig. Thoroughly clean the mating surfaces of the water outlet and . . .
    Fig. . . . the engine before installing a new gasket
    Fig. The jiggle valve must be in the up (12 o-clock) position after installation into the water outlet
Jan 19, 2011 | 2001 Mercury Sable
There are three hookups in back of refrigerator. Do I need to run 3 differen tlines of water supply?
To the best of my knowledge there is only ONE source connection and 2 internal connections that would connect to the water inlet valve assembly. This almost sounds like someone removed the inlet water valve and left it off of the unit. (Or.. the water valve was never connected at all)
The plastic tubing just presses into each of the water inlet water valve holes. you have a 50/50 chance of getting the connections correct if they are not labeled. If it is connected incorrectly when you depress water dispense the ice maker will over fill with water. (Swap the connections)
The inlet water valve will look just like this one. It will have 2 inside connections and one external connection. (see link) http://www.fixya.com/uploads/images/1E1A1B9.jpg
There should also be Two black and flat 2 pin electrical connectors dangling if the water valve was removed.
Take a look and let me know if your water valve is missing.
Thanks for choosing FixYa.
Kelly
Dec 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
How important is it to vacuum coils on a 632S sub zero? How often should it be done? What happends if coils aren't vacuumed regularly?
once a month would be ideal. It prevents the unit from dissappating heat which effects the way the unit cools and runs less efficiently.
Jan 16, 2009 | Sub-Zero 632 / S
Sub zero 632S error code 21
EC 21 has nothing to do with the refigerator. From the 600-2 series service manual page 3-21 EC 21 is Defrost Overheat fault.
The defrost system is only in the freezer and on a completely seperate refrigeration system. Clear the EC by holding the bell key pad down until you here a tone this is going to be a minimum of 15 but can be as long as 30 depending on the generation of your appliance. The part that you will most likely need to replace is the defrost terminator which stops the defrost cycle. You may have also had a problem in the refrigeration section which did fix by yourself, good job.
Oct 22, 2008 | Sub-Zero 632 / S
My system is
I guess I'm missing something here?
Mar 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Mavt634 cold water comes out the hot water inlet connection
Need to make sure that the water connections are correct - first that the hot water hose and cold water hose have not been interchanged and then if they are correct try interchanging the electrical connections to the water valves.
Mar 10, 2008 | Washing Machines
Sub-Zero 632 / S Logo
43 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
