Question about Electrolux Ovens
My old oven wiring has ph1,ph2 is this the same as a1,a2
I want to swap my oven out myself
3 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: i need a schematic for
Hi fcollin,
Here is Bakers Pride website for documents: http://www.bakerspride.com/manuals.asp
Down at the bottom of this page are wiring diagram documents. Closer to the top you'll p44s. Click on that and it will tell you what phase you will be looking at, ph 1 or ph3, according to your serial number.
Then you'll find your diagram according to the phase and your voltage.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on Apr 16, 2011
  • 405 Answers
SOURCE: my wires are labeled A1,A2 ,A3 and A4 .how do they
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps..
Posted on Jul 07, 2011
Simpson stove has 2 2PH, 1 N and 1 E poles, but power lines only 3 wires-1 red, 1 black and 1 green. How to connect the wires to stove.
I believe the proper sequence is red to ph1 black to ph 2 and green to N and ground. Newer ovens do require a 4 wire plug and this is th esetup for them
Apr 02, 2014 | Ovens
High limit switch keeps triping on tornado oven and ir temp doesnt move ir elemnt was repaced as well the i/o board
the K4/K5 relay tells the convection circuit AND the IR circuit to allow voltage to the elements.. if it is bad you will not get 1 or other or even both.. if you have convection heat and you are positive that the ir element and I/O board are good then swap the b1/b2 terminals with the a1/a2 terminals on that relay and retest.. if the IR now works then order the new K4/K5 relay. it is a common issue with them. the relay is behind the blower motor on the right side.. 3 screws to remove the blower and that relay is right behind it. it is the only relay with a single orange wire and the other 3 are blue.
Oct 05, 2011 | TurboChef C3 Single Oven
My wires are labeled A1,A2 ,A3 and A4 .how do they connect to the terminal block
Apr 16, 2011 | Bakers Pride P-44S Oven
My 16 month old whirlpool inegrated oven has a fault code F03 on screen. How can i fix this myself?
The F 03 code indicates a failure with the temperature sensor.
The sensor comes into the oven cavity on the back wall and is a little smaller than a pencil. The most common reason for this error is a wire connection between the sensor and the control board.
You can measure the sensor if you have access to a good ohm meter. It should read about 1080 ohms at room temperature if it is good.
Aug 01, 2010 | Ovens
Installing part 903091-9051 in a wall oven Frigidare FEB24S2ASB
YES ITS NOT SO BAD. I RECOMEND TAKING ONE WIRE OFF THE OLD AND PLUGGING ON THE NEW ONE AT A TIME SO YOU DONT MISSWIRE.
Mar 07, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
I'm replacing an old electric range with a new one. The old wiring is a black, white,and green, 3 wires. The new electric range calls for black, white, red,and green, 4 wires. How do I set it up and get it...
Outstanding question, ask the guys:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
I want to know myself.
Sep 13, 2009 | Tappan 30IN ELEC IGNa Oven
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
Oven element replacement- Simpson eziset electric
hiya
firstly make sure the power is isolated before removing any panels.
sometimes the element will just screw out from the inside of the oven and should pull through into the oven compartment with the wires attached, simply remove the wires, replace the element and refit any panels.
hope this helps
please dnt forget to rate the helpfulness of this reply thanks kj
Nov 11, 2008 | Ovens
Ovens Logo
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
