Question about Canon LASER SHOT LBP 3360 Printer
41 VRF FORM PAPIER - Canon LASER SHOT LBP 3360 Printer
H2 error on ODU display
https://www.carrierair.com.au/installer-and-technical-support/fault-codes/
Check the links to talk to a technician or service. I find no easy access to matching a sheet of error codes with your carrier VRF on the web. I encounter codes but the sheets fail to identify the models! Those codes refer to a decrease malfunction which defies interpretation by any but an air conditioning technician. So, the most direct route to your query answer is at the above link.
Jun 16, 2017 | Carrier Heating & Cooling
Year of manufacture of this gun?
Need make and model as well and the serial number
Google
smith and wesson model 41 serial numbers
and you will end up here
  • S&W Model 41 serial number search - Smith & Wesson Forum smith-wessonforum.com > ... > Smith & Wesson Semi-Auto
    • 35 POSTS
    • FIRST POST: 2012-01-05
    2016-01-18 · Hi everyone....I am looking at a S&W Model 41 22 lr. I`m interested in finding out what year it was made in. The serial number is UAV1XXX. is there a ...
  • Model 41 .22 LR Need Help to Determine Year of Manufacture www.smithandwessonforums.com/forum/s-w-semi-auto-pistols-forum/...
    • 9 POSTS
    • FIRST POST: 2011-08-14
    2013-09-30 · model 41 serial numbers, s&w model 41 serial number dates, s&w model 41 serial numbers, smith & wesson model 41 serial numbers, smith and wesson model 41 ...
  • http://www.bing.com/search?q=smith+and+wesson+model+41+serial+numbers&qs=n&form=QBRE&pq=smith+and+wesson+model+41+serial+numbers&sc=1-40&sp=-1&sk=&cvid=2E13F1737AF242EB90CE478CC92D51DD
    May 23, 2016 | Sport & Outdoor - Others
    Comment enlever l erreur sc194 bourrage papier porte de droite
    faudrait bien regarder le sensor, il y a surement un bout de papier la
    Oct 06, 2014 | Gestetner RT45 1500 Sheet LCT 411339
    J'ai 1 hp photosmart C6180 qui affiche toujours bourrage papier
    Le caoutchouc marche dans les usures de cylindres, les faisant en bas lisser, donc ils ne prendront pas le papier. Quelquefois, ils sont vieillis, qui aussi les donne une texture arrondie plus lisse, causant des embouteillages. La r?paration rapide est d'animer ce cylindre avec un m?lange d'alcool et de savon. Etouffer un chiffon avec la solution et essuyer les cylindres nettoie avec cela. Cela est la marque les plus flexible et les embouteillages en papier cesseront. Si vous avez l'intention de garder votre imprimante
    Jul 21, 2011 | HP Photosmart C6180 All-In-One InkJet...
    Goede middag, Heb IK EEN Epson Stylus C46 Beide lampjes bovenop blijven knipperen om en om, Krijg ookGeen papier toevoer Wat Moet IK DOEN?? mvr. lips
    Hallo,
    Er is een online handleiding voor de C46 met de volgende link voor
    internet explorer:
    http://support.epson-europe.com/onlineguides/nl/sc46/index.htm
    Normale bedrijfssituatie:
    Als beide lampjes knipperen en het papier is op gegaan tijdens afdrukken:
    Leg papier in en druk op de knop met de "druppel+pagina" om de afdruktaak in het geheugen van de printer te voltooien.
    Wanneer papier is vastgelopen:
    Zet de printer uit en verwijder voorzichtig alle papier.
    Zie de volgende pagina van de online handleiding: onderaan staat alle uitleg over beide lampjes indicaties:
    http://support.epson-europe.com/onlineguides/nl/sc46/ref_g/parts_1.htm
    Meer uitleg nodig ? Schrijf dan nieuwe tekst in dit bericht.
    May 31, 2010 | Epson Stylus C46 InkJet Printer
    Canon LASER SHOT LBP 3360 Printer Logo
    42 people viewed this question
    old marine
    old marine
