Question about Cell Phones
Okia x2-00 white screen ,vibrate and then power off 100% solution hereGUIES JUST REMOVE THE RESISTOR PLACED ON THE RIGHT SIDE OF CAMERA SWITCH AND MAKE JUMPER INSTEAD OF THE RESISTOR ENNJJOYYY I try t
White display
  • 452 Answers
SOURCE: whit screen
Try with the new battery and check it works or not.Otherwise consult hardware vendor for the same.
Posted on Nov 12, 2007
  • 48 Answers
SOURCE: white screen on kodak C643 easy share digital camera
This sounds like either a broken LCD screen (they don't have to display the liquid in the display to be broken) or a cable that has partially been disabled.
You can try to open the case and reseat the LCD cable and try that.
Posted on Dec 18, 2007
SOURCE: innovage benfini salons professional style clippers
Return it back to store as fast as you can, show these complaints and request an immediate refund from a seller.
Posted on Jan 12, 2009
SOURCE: nokia n70 freezing after few minutes
no software instal
Posted on Feb 19, 2009
nsejoshua
  • 97 Answers
SOURCE: white display on the screen.
Its a software problem... Try to see a mobile technician maybe it needs to be reformatted...
Posted on Jun 17, 2009
Lcd screen lines in sony handycam dcrsr45. when i start camcorder there is vibration type lines in lcd screen,not white lines just picture and horizontal vibrations which are recorded in camera.it was...
The most common problem with this camcorder is the lcd cable assy. It is the cable that comes in from the lcd panel assy to the internal board assy. I have seen possibly 100 of these cameras and different models and this fixes it everytime.
I hope this helps.
Sep 05, 2010 | Sony Handycam® DCRSR45 HDD Camcorder
My cybershot camera has no display only display white screen
I fixed the camera myself as follows:
1. Hold camera firmly in left hand
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
It worked, now the LCD is working again for free.
Jul 27, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
How easy is sony kp-43ht20 converge ic chip replacement?
Easy is not a good description... due to the cabinet size of this model, there is not much room to work. You will need to disconnect a lot and unfasten a lot of wires so that you can pull the chassis out of the lower cabinet. Then you will need to remove the D board screws and the Convergence amplifier screws (the amp will be right in your face, you can;t miss them... 2 large heat sinks right in a row. After you do that, you will probably need to change 1 of the 2 fuse links on the G board (the board the power cord plugs into). These are the supply Vcc for the convergence amps. They are 5A fuse links located on the upper/mid, right side on the PCB. Use caution, you need to discharge the circuit before you place the fuse in or you may pop the new (or remaining old) fuse. it's best to use a 100 ohm resistor to bleed the circuit on the input side of the fuse. You can do this by touching a legs of the resistor to the fuses legs. To be sure, just do it on both sides of the fuses. (resistor touch to fuse 1, side 1... and also to fuse 2, side 1. Repeat on other side of fuses.) Bleed for at least 5 seconds. After that, change the fuse(s), put it back together, power it up... press the Flash Focus button on the front of the TV. It you need to do further convergence, you can find information all over the place... or post it here.
Mar 13, 2010 | Sony KP-43HT20 43" Rear Projection...
Power on screen white
lens assembly (barrel unit) struck up. slightly push lens while power off & pull the lens while power on. repeat this 2 to 3 times it will works. dont apply any oil in the barrel unit. but you may use body spray or room spray to solve this issue permanently
Feb 06, 2010 | Samsung Digimax A503 Digital Camera
Dead Computer
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Jul 24, 2009 | Okia 420w UL Approved ATX Computer Power...
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
2002 Buick Century
The blower motor resistor is located on the back of the blower motor housing under the dash on the passenger side. It can be difficult to get at, but it is doable. Be ready with the ibuprofen the next day for your sore back. Remove the cover panel from beneath the dash on the passenger side. Unplug the power 'ribbon' wires leading to the resistor. Unplug the wires that lead from the resistor to the blower motor housing. There are usually two, one black and one purple that share the same plug. Remove the short hose that leads from the blower motor housing to the ventilation system ducts. Remove the blower motor by removing the three hex screws that hold it in place. Remove the resistor by removing the three hex screws that hold it in place. The resistor is right against the firewall so two of the screws are very difficult to reach. A slender flexible socket extension will make the job easier. Attach the new resistor in place using the same hex screws. Only 1 or 2 of the original three are needed (the part is very light) if you do not feel like fighting with the ones next to the firewall. Reattach the blower motor and reconnect the hose. Plug the power cable wires back into the resistor and the wire from the resistor back into the blower motor.
I believe the driver door switch just pops out if you pry on it, but not absolutely sure on this one.
Sep 11, 2008 | 2002 Buick Century
Sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
Parallel connection of power mosfets with two of 5 smoking
The IRFZ46N are n channel high speed switches . They basicly drive the Mosfets. Sounds like you have some problem there my friend, and unless you paid alot for this amp. Its going to need probobly all the n channel switches as well as every mosfet + the bias resistors repalced. Before plugging in the amp jump out the fuse with a 100 watt light bulb.. If the bulb glows brightly when you apply power there is still a short in the unit and could be in the switching power supply section of the amp. If it glows bright and dims, The shorts are most likly gone. The bulb will minimize the amount of current the unit can draw and most of the time wont let the new parts blow out. Check out this service number and see if they can help you. Good Luck Main support number 978-823-0300
Jul 26, 2006 | Pyramid PB779X Car Audio Amplifier
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
