Question about RCA Televison & Video
How to hook up a dvd player to RCA model G25343WK
I do not have the remote control for my RCA console tv model G25343WK I can not get the tv to connect to the dvd?
  • 35 Answers
SOURCE: RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Posted on Dec 21, 2007
SOURCE: Durabrand model BH2004D
I am not sure about Direct TV but dish network does not allow the hookup to go through their box...it must go through the TV only. Speaking with Duraband at 1-800-256-2487 confirms you have to have a Duraband remote and universals won't program to it. Ask for parts dept. and order a new remote. Sorry - not good news for me either!!!
Posted on Jan 11, 2008
SOURCE: PROGRAMING MY TOSHIBA REMOTE TO CONTROL MY RCA DVD
I forgot the pin code on the remote, how can I over ride it?
Posted on Feb 29, 2008
  • 48 Answers
SOURCE: connect magnavox dvd to ge tv HELP!
There are a few options to connect an older t.v. with a DVD player.
  1. You can connect your new DVD player to a VCR....not recommended as quality loss will occur....use RCA plugs (Red/white/yellow) but it is easy...and many people have an extra one around
  2. plug one end of RCA cord into DVD player, other end to VCR (colour match red plug to red cord)
  3. then to connect VCR to TV...use the coax VIDEO OUT (on VCR) to the TV
  4. OR you can purchase an RF modulator like this at http://www.amazon.com/exec/obidos/tg/stores/detail/-/electronics/B00009MDBN#moreAboutThisProduct
  5. this option has a greater cost...but the picture quality will not suffer....Note..you will not have Surround sound...but as it is an older tv. you were not used to that anyway..
Great way to keep an older working t.v. out of the landfill
hope this helps!
Posted on Oct 09, 2008
  • 76 Answers
SOURCE: can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Posted on Dec 03, 2008
How do I get dvd's to play on a 1990's model RCA tv without a tv remote?
You need an RF modulator and the proper cable(s) so that the DVD player can connect to the old TV coax input. See this video for the procedure.
TVs DVD Players How to Hook Up DVD Player to TV Having Only One RF or...
May 09, 2016 | RCA Televison & Video
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Dec 17, 2014 | Orion BDP3959 Player
Codes for bp59-00016 samsung remote to hook up a rca dvd player
Try the code 002 for an RCA DVD player for the BP59-00016 remote. This is the only code given for RCA DVD players for several Samsung TV universal remotes (BP59-0007 and the BP59-00016A). A manual for a TV with the BP59-00016A remote is here: http://downloadcenter.samsung.com/content/UM/200303/20030325191047000_L62A_ENG_1210.pdf .
You may need to check the age of the remote. The codes in a universal remote generally only control those devices released 6 months or more before the remote was programmed. If your RCA DVD player is newer than your remote, you may need a new remote.
I hope this helps.
Oct 12, 2011 | Samsung BP59-00016A Remote Control
Howdo I hook a DVD player up to this model?
The easiest way would be to hook it up using the composite cables from the DVD player to the Rear of the TV.
First safely and slowly turn your TV around you should see inputs in the rear of the TV.
Second identify your composite inputs. They will be visible via the standard RCA Composite colors, which are Red(Audio), White(audio), and Yellow(Video)
Third Once you have found the RCA Composite Inputs, Take the cable which are inserted into the DVD player and Plug it into the TV's Composite Inputs.
Once all that is done, turn on your DVD player. Then using your TV's remote Press the "TV/VCR" / "Source" / "Input" button on your remote till you see video from your dvd player displayed on your TV.
Here is a link to the User Manual:
http://www2.panasonic.com/consumer-electronics/support/TV-Combos/model.PV-C2540
Hope this Helps.
Mar 18, 2011 | Panasonic PV-C2540 25 in. Combo
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Rca remote control code list
i need the codes for a rcu404 universal remote for sony dvd player
Jan 11, 2009 | RCA RCU404 Remote Control
RCA F32450 TV can not get the TV to display the DVD menu
You can get a remote from Electronicadventure.us for $29.95. The remote number you are looking for is RCA-GE-PROSCAN 242524
Nov 15, 2008 | RCA F32650 32" TV
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Dec 21, 2007 | Televison & Video
Hooking up a DVD Player with NO remote
Some TV's will let you access inputs by going through the channels to the very end and see if it works.
Jul 29, 2007 | RCA F25674GY 25" TV
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
