Question about JVC Car Audio & Video
Car radio will not turn on
No power is going to the car radio
  • 65 Answers
Check the car fuse box, most probably the car fuse to supply the radio is blow off.
Posted on Nov 28, 2013
Looking for ford figo radio wiring diagram
power to the radio is good ---now all you probably need is the anti-theft code for the radio to turn it on.Go on line to free radio codes and find your make and model of radio
Dec 16, 2014 | Ford Cars & Trucks
Radio wont turn on.
You have a power wire going to your on off switch you should also have a power going to a memory wire to keep your stations and clock intact.
Apr 21, 2013 | 1997 Toyota Camry
My battery died so i replaced it and now my radio won't come on. Tried holding down power button, turning on and off ignition. Still has no power. the battery was out of the car for about 4 hours.
If your radio has anti-theft system you will have to go to the dealer and get the accss code to reactivate the radio if you dont have the code already. GM vehicles with anti-theft radios will lock when power is lost to the system if the radio is not turned off prior to battery disconnect or dying.
Jul 24, 2011 | 2005 Chevrolet Cobalt
How do I get to radio tune
Turn XM Roady2 'on' using the POWER switch. Go to MENU and go the FM Frequency. Select your frequency of an empty channel in your area, then turn off the Roady2 using the POWER switch. Do NOT do this by turning the car on and off as it tends not to save any settings when you do that. Always use the POWER button. Also, the website 'Radio-Locator' has a utility that will help you find an EMPTY FM channel in your are for your XM radio to use! Good luck and let me know how it works out for you- okay?
Jun 12, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
Antenna will not go up or down,but still has
Have the antenna motor tested re place it if not working if antenna motor is working you will need a new antenna mast and antenna cable to remove this unscrew the washer nut at the base of the antenna and turn radio on antenna should push up and play out he cable to replace insert new cable and turn radio off it will draw cable in and antenna tighten washer nut and your dne
Aug 07, 2009 | 1993 Chevrolet Corvette
My power antenna won't go down when i turn off my car or my radio. i have a 1995 chevy impala ss
this is normal the power antenna gets power from the radio and unless the radio is shut off either from powering it down or turning off the car it will stay up. if it is an aftermarket stereo and is staying up when you are on cd's check to make sure that your antenna is hooked to the antenna output on the radio and not the system remote as the system remote is hot any time the radio is powered to run amplifiers.
May 19, 2009 | 1995 Chevrolet Impala
The radio wont turn off when i turn the key
You could be hooking up the main power to a full time hot rather than the radio circuit. Use a test light to find the switchable hot and hook up your power wire to it, then then memory for the radio goes to the full time hot.
Apr 14, 2009 | 1991 Chevrolet S-10 Blazer
Does the power antenna turn the radio on?
antenna fonction is to capture radio wave for channel
got problem within radio best place is to go to radio
shop
Apr 09, 2009 | 1997 Saturn Lw 4dr Wagon
Radio shuts off when I turn the lights off
does it actually turn off... or do the lites just go off... is that an aftermarket radio... it sounds like they have used the power wire that puts power to the display onto the power wire for running the radio.
Robert
Dec 18, 2008 | 1997 Mercury Mountaineer
Car Audio & Video Logo
26 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
