You would need to look at the connection, see if the server is on and working? Make suer you installed the drivers correctly.
How can I find the Windows Server 2008 driver files for the Adaptec CERC SATA1.5/6ch?
OK, EZPZ.
These drivers will install when you first start installing windows 2008 server. You'll see a option that says: Hit F4 for any further drivers needed for windows to install. I think it's F4. You can place these drivers on a thumb drive OR a CD - you must extract the files on to a thumb drive. At the very start of the windows install you'll see the option for additional drivers.
First screen - Success
SCSI - Yes, that is correct. Correct, but This isn't a SCSI controller
If you choose the SCSI driver from Dell, on the disk, you won't get...
This screen. This screen means that windows could not find any driver for your drive and there for, you must start over - Same steps.
But make sure you choose the correct driver - you might have to try a few that are in the list.
Greatest of luck - EZPZ
Have a great night..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Aug 11, 2014 | Dell PowerEdge SC1420 Dual Xeon 3.2GHz 2GB...
Poweredge 6600 not showing display
If you have multiple video connections (onboard from motherboard, usually vertical or stand alone video card, usually horizontal) that you plug into the stand alone card, as the onboard is normally disabled when the expansion is installed. Verify the cable and monitor both work and that the monitor is on the correct input. Finally try another video card, if you have one available. Even if the drivers are not correct, etc, you should still see a boot screen.
Nov 13, 2013 | Dell PowerEdge 6600...
How to connect my printer to a router
This model Canon printer has onlt an USB connection to a computer.
The only way to connect this printer to a router is to install a printer server with an USB connector, connect the printer to the print server and then connect the print server to the router using a LAN cable.
The printer driver needs to be installed on all the computers on your network and then to the printer properties then Port tab and add a TCP/IP port then configure this port with the print server's IP address.
Do a test print and if the test print is OK then printer is installed correctly.
May 29, 2012 | Canon iP2700 Inkjet Photo Printer
I am usind Branded Dell Precision 690 Desktop Machine, i have already windows xp installed in it, but i want to install windows 2003 Server in it, but its creating a lots of issues to me to install server...
Before installing a Windoze server (no matter what flavour) you always need to verify the compatibility (drivers) with the machine's hardware... A Windoze XP driver will rarely work for a server environment... Micro$oft built all servers version to run in server machine type... further more you also need to verify softwar compatibility as well... as not all workstation software is compatible with server environments... and your machine advertises that it is a WORKSTATION NOT A SERVER...
Cheers!
Jul 28, 2011 | Dell Precision Workstation 690 - 750W...
I bought Few HP proliant DL 380 G4 servers....they do not have any operating system...i want to install windows server 2000 but it keeps giving me a message " "Setup didnt find any hard drives...
First, make sure all your connections are secure and the BIOS is seeing your hard drives. When you start the install of Server 2000, you will see a prompt at the bottom of the screen saying if you have third party software to install press any key. (or something to that effect.) Press any key and install the needed software drives for the SCSI controller. You will need this to move forward. If you do not have the drivers, you will need to download them to a cd or usb drive to complete your server install.
Good Luck.
C2Solutions
Jul 08, 2011 | HP Compaq ProLiant DL380 G4 Server
I NEED THE PRINTER DRIVER FOR ePSON TM-P2.01
Driver related problems can be solved by using this program Driver Update (including your epson driver files). Wish you best of luck
Chris
May 12, 2009 | Epson TM-U220 Matrix Printer
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link: http://iogear.com/support/dm/driver/GMFPSU01#display
Nov 13, 2007 | IOGear GPSU21 Print Server
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
